Car ramps
Discussion in 'Gen 4 Prius Main Forum' started by Jover, Aug 26, 2017.
  1. Jover
    Jover Junior Member
    Virginia
    Four Touring
    We'll it's time for me to start oil changes following Toyota Care. What ramps are you guys buying and are there any issues. My old ramps do not fit.
    Thanks.
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    My son's ramps did not work for me. We had a dry drainage ditch near our house. I straddled it with the Prius enough to get underneath and change the oil.
    Fostel and RCO like this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    I thought I read that Gen 4 is 0.5 inch lower.
  5. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    I plan on making a set of wood ramps similar to the ones in the link below. Much more practical for keeping the car level although storage may pose an issue.
    Wood Ramps
    Prodigyplace and Raytheeagle like this.
  6. Tour de Prius
    Tour de Prius New Member
    23
    Michigan
    Three Touring
    Why not use long 2x6s place on the ramps to decrease the approach angle? One on the ramp, use as normally?
    kithmo likes this.
  7. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Build your own. Most ramps you can buy are too "steep", that is they hit the car before the wheel is lifted enough. I use two 2X12 boards each about 4 ft long, with a 2x4 screwed to the end as a "wheel stop" (so I don't drive off the end). The high end is placed on a screwed together block of 4x4 and 2x6 pieces. This allows me to get the car high enough to open the oil change "door" on the undertray. They store nicely standing up in a corner. The only caveat is you have to use the "P" brake and a wheel chock because the car is sitting on a steep surface, but I haven't had a problem with this so far.
  8. PRI6080
    PRI6080 Junior Member
    22
    Pictures of your ramps?
    Fostel likes this.
  9. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Late to the party, but for those searching, the Harbor Freight plastic ramps work, and seem to be far more solid than the sectioned, seemingly dangerous RhinoGear ramps.
    With nearly new tires had about 1/2 inch clearance from the front plastic to the ramp to hit the ramp. Very easy.
    These: 13,000 Lb. Portable Vehicle Ramp Set
    are seemingly the same as this other brand on Amazon
    #9 Mambo Dave, Dec 22, 2021
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    Not cheap, but these are the best.
    Mambo Dave likes this.
  11. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    They look really solid. I saw them, but could not judge if they were shallow enough of a rise for Gen4's. But, also, considering changing the oil is about once a year, I wasn't looking to spend that much.
