Car revving high as I brake and at idle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RTracy, Oct 11, 2018.
  1. RTracy
    RTracy New Member
    Il
    Tonight my car started rivving up as I was braking stopped after 20 seconds or so. Did it again two more times on way home. Pulled into drive and it did it even in park. Not sure what to do next. Closest dealership is an hours drive away dont know if I should chance it.
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    1. The throttle assembly may have being clogged with lots of carbon deposits, especially on the butterfly thingy.
    You could remove and service that with carb cleaner, or remove the air intake hose, and spray the carb cleaner into the throttle assembly, as the engine is idling (trying putting the engine on inspection mode or something, to allow for extended idling).
    2. There maybe a vacuum leak somewhere, that's allowing unmetered air into the engine.
    That might account for the high revving. The ECU is trying to compensate for a lean situation.
    3. The throttle assembly might be faulty (I mean, the electronic small motor that controls idling).
    Keep us posted pls
    RTracy and Pluggo like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    The engine will rev if the traction battery is full to keep from overcharging the battery
  4. Mendel Leisk
    38,734
    FWIW, the one instance I've noticed engine rev up, and it's quite reliable, is after having the 12 volt battery disconnected. For the next maybe 2 start up, it'll rev up for a few seconds, like it's going through some calibration.
    sega64 and scona like this.
  5. bisco
    49,504
    welcome!
    hybrid battery might be going south, how many miles on her?
    i would risk the drive to the dealer
  6. RTracy
    RTracy New Member
    Il
    I got the throttle cleaned and revving stopped. But now gas millage is way down. Could it be air leakage?
  7. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Any check engine light on the dashboard? If no, check the spark plugs. If worn excessively, they'd cause poor mpg issues.
