Car rolls forward after stopping
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by duanerw, Feb 7, 2010.
  1. duanerw
    duanerw senior member
    140
    lexington ky
    2013 Prius v wagon
    my first prius was an 05 and now i have a 2010.
    I have had it roll forward after stopping and starting to get out of my car.when i press the start button it quits rolling.I think it is old age or stupidly
  2. Joe166
    Joe166 New Member
    720
    96
    South Florida
    The car is a 2010, so it is certainly not old, and it is far from stupid. I would look into driver error! I have done this once or twice, but only because I forgot to push either P or the start button.
  3. IMUSA76
    IMUSA76 IMUSA76
    Rhode Island
    I always apply the E-brake eveytime I get out of the car... the DVD that came in the manual recomended that we do that.
  4. duanerw
    140
    lexington ky
    2013 Prius v wagon
    i wasnt thinking car was old.im old and getting forgetful.guess we all do stupid things from time to time and it was my turn.
  5. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    I have noticed this as well. The car rolls fwd slightly(few inches) even after hitting the P button to engage parking. When I showed this to a local Toyota tech he claimed it was "normal" for hybrids???
    I am not convinced!
    Let's see there's also that braking glitch over bumps...
    Ever grabby and sensitive brake pedal...
    I guess it's all "normal" for Prius...wow
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It is normal. The Prius uses a gear-like parking pawl to lock the drivetrain when in park. This gear-like system is very robust, but it does introduce a small amount of play in the parking pawl. What you feel is the play being taken up.
    As others have said, if this play is an issue, use the parking brake.
    Tom
  7. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    My Lexus does this when I don't apply the parking brake. I always apply the parking brake and don't have this issue.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Our Kia van moves/rolls just as much as our Prius when in park. No way is it an inch or two either...
  9. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Every car or truck i have ever owned or drove did this. Some trucks/cars i can push 6 inches when they are in park.
    1. Completly normal
    2. I would also sugest using your parking brake, it will prevent this from happing and also save a tiny bit of wear on the PSD and may prevent your car from rolling away and hurting someone if some how the park failed.
    2 people like this.
  10. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    mine seems to roll in excessively, maybe 2 inches or more...much more noticeable than any other automatics I've driven.
    Is there a way to tighten this pawl play?
  11. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Folks,
    You are getting way down in the weeds here.
    This is two inches: |<----------- 2" ---------->|
    Other than self-inflicted damage to the parking pawl, what possible
    significance can this have in the real world? When you're parking, you
    can't even see the clearance between the front bumper and any
    obstruction.
    So what, is Toyota supposed to recall the car and move the engine bay
    to the rear of the car a la Porsche to make those 2 inches meaningful?
    If the self-discipline required to use the parking brake whenever the
    car is parked is overly much to expect, then the next-best solution is
    to tighten up or replace the nut behind the steering wheel. :p
    2 people like this.
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I seriously hope you are joking....
  13. qbee42
    18,058
    3,073
    Northern Michigan
    Shhhhhh. :tape: What are you trying to do to me? I've been telling my wife for years that that is NINE inches. Don't ruin a good thing.
    Tom
  14. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Tom,
    There must be a lot of that going on. It may help explain why where
    discrimination between small distances matters, men ARE better than
    women at parking: (Note: this is not the more broadly defined
    driving.)
    Feminist scientists have proven what sexist motorists have suspected all
    along. Read more here.
    That's your take on it. What does the missus say? :D
  15. Rhino
    Rhino New Member
    460
    U.S.A.
    For whatever reason, the delay between putting it into park, taking you foot off the brake, and feeling the final settling of the car is delayed - especially if you are parked very close to level so the car rolls slowly. So you are tying to open the door and suddenly you feel the minor stopping sensation.
    It is not a big deal. You get used to it. And it is not a safety issue. If moving the car 2 inches causes a safety issue, you are parking too close to danger.
    On a side issue, almost every car I had have a parking brake that is really weak. If you don't put the car in park but in neutral, the car will surely roll away by itself. Can't they make the parking brake stronger? It would seem safer if you live in, say, a hilly place like SF.
  16. adamace1
    1,403
    191
    Charlotte, NC
    Thats weird are you applying the parking brake hard enuff?
  17. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Or maybe they are not adjusted properly? I don't have any problems here in SF with either drum or disc rear parking brakes.
  18. qbee42
    18,058
    3,073
    Northern Michigan
    "I can't see the TV", or sometimes a simple "GET OFF!"
    Tom
  19. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Very simple
    USE THE PARKING BRAKE!
    The parking brake is to be used EVERY time you park the car. Its not just for emergencies...its not just for hills. Its for PARKING. The PARKING BRAKE. In many states...its the law actually.
    If you use the parking brake the vehicle will not move when you release the service brake because the parking brake will not allow the vehicle to settle back on the parking prawl.
    This is true in EVERY VEHICLE. Every little thing about your Prius is not a god awful death sentance.
  20. El Gato
    El Gato Junior Member
    23
    Austin, TX
    My car does this occasionally, mostly when on a hill. Solution: parking brake, it has worked every time.
