Car Scanner Pro app for Diagnostics
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A.J, Oct 10, 2025.
  1. A.J
    A.J Junior Member
    60
    Worldwide
    Shows 0 RPM. Although my car Android unit is slow due to the 1GB RAM, But it fluctuates between -2 to 1 RPM sometimes.
  2. ChapmanF
    19,039
    In the photo attached to #61, I see that when the photo was taken, the car was stationary (0 km/h) and the engine was running (1200 RPM, idle speed).
    MG1 and MG2 are not both showing 0 RPM. MG2 is showing 0 RPM, as it always will when the car is stationary.
    MG1 is showing a non-zero RPM, as it must if the car is stationary and the engine is turning. The digits in the photo are fuzzy and I'm not sure exactly what Car Scanner is saying that MG1 RPM is. If the engine RPM is 1200 and the car is stationary, MG1 should be doing 4320 RPM. That's where your line will fall on the nomograph if you draw one between 1200 engine RPM and 0 MG2 RPM.
    That's all as was stated in #25 upthread.
    More directly to the question "when you put it in neutral, what RPMs do the MGs show?", the answer, as above, is exactly the same RPMs as you would see in P or D or R or B at the same engine RPM and road speed. The way the transmission is built, the mathematical ratios between those RPMs are fixed for good. Shifting to N doesn't make any sudden change in any of those RPMs. (The RPMs may subsequently trend down or up—all keeping the same ratios to each other—given that you're now rolling in neutral and rolling to a stop or picking up speed downhill.)
    Edit: I shouldn't really have said "keeping the same ratios to each other", but really should have said "keeping the same mathematical relationship to each other", that is, the relationship explained in #25 upthread.
    #62 ChapmanF, Oct 30, 2025
  3. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Exactly. That "mathematical relationship" allows one to calculate engine speed, ring gear speed (hence also road speed and MG2 speed), or MG1 speed when the other two of those variables is known. The algebraic relationship is rigidly fixed based on gear tooth counts, meaning it doesn't depend on method of measurement, transmission setting, or any other variable.
  4. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    I had a couple of dashes going, maybe 10 or so parameters.
    The phone got warm and battery % went down quickly.
    Any other see big battery use?
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Mine works fine while it's plugged into the charger.
    When I cheaped out last time I bought a Bluetooth module that drained the12V battery overnight. This one has a powersave feature that shuts off when not being accessed.
