Car shakes at high speeds
Discussion in 'Gen 2 Prius Main Forum' started by Cjandrade89, Apr 30, 2019.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The other issue may be bent wheels. The stock wheels are so easy to bend one good pothole.
    The best way to check the wheel for out of round is put the car on a lift and install the suspect wheel on the rear And then with car in the air spin that tire by hand and look for run out or wobble.
    Really easy to detect run out that way, while ago I was chasing the same issue vibration at speed and
    My usual tire store couldn’t figure it out bought new tires same issue. Went to another tire store and that tire tech figured it out using this method in about 5 minutes. I had 3 bent rims 1 was really bad,
    Apparently my wife’s hobby is finding big holes in the road and hitting them at speed.
    Skibob and SFO like this.
  2. prius_deep
    prius_deep Member
    105
    38
    road
    bought her with a salvage title.
    could be many things.
    I hear a thump whenever I let go of the gas peddle and right away step on the gas again
    your control arm(s) are bad.
  3. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Just to say, Gen2 Prii in good condition have probably been known to get up to 100 mph smoothly, so of course something wrong here.
    Hokie-Dave likes this.
  4. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I hear it does take a little time, but definitely possible. :D
  5. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Have you tried changing around tires yet? You have been getting a lot of suggestions but you have not mentioned trying any of them.
    Raytheeagle and edthefox5 like this.
