Car starting
Discussion in 'Gen 2 Prius Main Forum' started by Mebeksis, Jul 3, 2018.
  1. Mebeksis
    Mebeksis Junior Member
    53
    17
    Covington, GA
    Yesterday morning, I went to start my 2009, it didnt start, lights came on, but ready didnt and parking brake was flashing green. This suggested battery didnt have enough juice. Got it jumped and it started immediately. Drove multiple times all day (I'm a delivery driver, probably started it 15-16 times before coming home). Parked it around 6pm. It's now 7:30am and it is not starting again. Do I need to replace the small battery in the trunk?
  2. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    From what you have told us, that would seem like the thing to do.
    jerrymildred and Raytheeagle like this.
  3. Mebeksis
    53
    17
    Covington, GA
    Heh, first hybrid for me...was making sure I was looking at the correct battery.
    DLC82SV likes this.
  4. dolj
    dolj Senior Member
    8,604
    4,366
    I have to say, I've never seen the park brake flash green, before.
    kenoarto likes this.
  5. Mebeksis
    53
    17
    Covington, GA
    Are there two batteries on this car? The small one in the trunk and another one somewhere else? The reason I ask, I just had to jump the car again and when it came up the display was showing the battery almost full (which is where it was when I turn the car off)
  6. bisco
    52,538
    yes. the small one (12v) fires the computers and relays.
    the large one (hybrid battery) under the spare tire starts the engine and helps drive the vehicle.
  7. Mebeksis
    53
    17
    Covington, GA
    And is that one different from the one on the display I'm assuming?
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Yes, the 12v battery is located at the rear passenger side corner of your 2009. The HV battery is located under the trunk floor. The HV battery is the one displayed on your MFD and has the colored bars.
  9. bisco
    52,538
    correct. the display is for the hybrid (drive) battery. see my edit above.
  10. Mebeksis
    53
    17
    Covington, GA
    Okay so if I'm having trouble getting the car to turn on, that's definitely going to be the small one then, not the big one right?
  11. bisco
    52,538
    correct. if it even gets low, around 12.3 or 4 volts, by the time the voltage gets to the computer, it is outside the operating parameters.
  12. bisco
    52,538
    but it also has to do with the voltage when a load is put on it, which can really drop it down, even if it tests okay.
  13. bisco
    52,538
    the hybrid battery will light up the dash if it ever gets outside its operating parameters.
  14. Mebeksis
    53
    17
    Covington, GA
    Okay. Other than a dead or dying battery, is there anything else it could be that would cause symptoms like this?
  15. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    One thing you can do is to make sure the + and - cables are securely fastened to the battery terminals and the chassis end of the (-) cable is securely fastened to the rear wall of the trunk. If the 12v battery (the small one) is original, it's definitely time to install a new one.
    Your symptoms would lead me to believe you're at a 99% level of confidence that the 12v battery is at end of life.
    SFO likes this.
  16. bisco
    52,538
    not that i know of. since a jump fixed it, it should be the battery. might just need a charge, but no way to know without experimenting.
    any idea how old it is?
  17. Mebeksis
    53
    17
    Covington, GA
    Not a clue. I just bought the car in March. I've already dropped almost a grand into work on the brake system, does my hesitancy to just go buy a brand new battery. Is there anything that runs when the car is off? Like I've noticed a few times when I turn it off and get out there's something still running for a few seconds afterwards.
  18. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Any AutoZone / AdvanceAuto/etc should be able to test your 12v battery very quickly. Most places (even I have one) have an electronic battery tester that's about the size of a voltmeter. It will connect to the battery just like a jump start cable. Most of them you'll have to enter the CCA value of the battery so it can compare it's tested value to the rated value. If you have a SKS model prius, the CCA of the battery is 325, if you have the non-sks model, the battery CCA is 272.
    The electronic tester will tell you the battery voltage, whether it has an internal cell failing, and what it's estimated capacity is. Most of the tests it performs are pass/fail. It's very very quick.
  19. Mebeksis
    53
    17
    Covington, GA
    How do I find out which one I have? Is it written on something or something?
  20. bisco
    52,538
    sks means you can open the drivers door with the fob in your pocket.
