Car starting
Discussion in 'Gen 2 Prius Main Forum' started by Mebeksis, Jul 3, 2018.
  1. bisco
    52,863
    yes, the 12v operates some things while the car is off. it also has a capacitor for emergency braking, should it run too low.
  2. Mebeksis
    Mebeksis Junior Member
    53
    17
    Covington, GA
    Like automatically? No, to my knowledge it doesn't work that way. I've always had to press the button on the fob to open the doors.
    52,863
    that would be non sks, unless something is wrong. check the bottom of the dash under the steering wheel for an sks on/off button.
  4. Mebeksis
    53
    17
    Covington, GA
    The only buttons or anything I see under the steering column or what looks like a tire pressure monitor reset thing. It looks something like this: (. . ) with the word reset under it
  5. bisco
    52,863
    yep, that is tpms. so you want a non sks battery. double check the measurements before buying, the sks is larger and won't fit.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Info for all...
    SKS model....S46B24R and CCA=325
    NON SKS model....S34B20R....CCA=272
    If I remember right, it has the 20H rating on top near the model number
    SFO likes this.
  8. Mebeksis
    53
    17
    Covington, GA
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    Which is a dead give away that the battery is dead. Or maybe not well connected. Given that it jumped and ran OK, but went weak after lots of short runs that didn't let it get well charged, I'd say it's the 12V battery. But it only takes a few seconds to find out.
    kenoarto likes this.
  10. Mebeksis
    53
    17
    Covington, GA
    Trying to find a battery and all the ones I can find are the smart key batteries. Tried auto zone, O'Reilly's, advance auto, and Walmart. Do I need to look elsewhere or will the bigger batteries work?
  11. kenoarto
    398
    Chicago, IL
    Go to a Toyota dealer. On sale the battery costs $175.
    jerrymildred likes this.
  12. Mebeksis
    53
    17
    Covington, GA
    They quoted 300 to me earlier today.
  13. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    You may want to look at the battery that's installed in your car to verify which model it is. It would stink to go hunting for a small battery and then find out a previous owner changed over to the larger model, like some owners do.
    jerrymildred and Raytheeagle like this.
  14. Mebeksis
    53
    17
    Covington, GA
    Raytheeagle likes this.
  15. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Looks a lot like this one. I bought this one about a year ago to use as a back-up in case any of our Prii had a battery failure. It tested at 375CCA about 5 days ago using my electronic tester. If it comes down to it and you can't find a replacement within your time requirements....I'd sell it for what I have in it. It's been installed twice and has about 3 days of use on it
  16. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I also think I have a large battery mount in the shop if you're interested in switching over to the larger model, which seems to be more readily available.
    It wouldn't be too hard to just completely remove the small mount system, pack a towel into the bottom of the cubby and drop a large model battery on top of it. Then hook up your cables. Stuff some rags on the three sides of the battery away from the trunk vent to keep battery from bouncing around. Order a large mount kit.
    #36 TMR-JWAP, Jul 3, 2018
  17. dolj
    dolj Senior Member
    8,651
    4,401
    Wellington, New Zealand
    The bigger battery will work very well and would be a better option. You just need to swap the battery bracket which cost about $20-25 from the dealer or grab the one TMR-JWAP has, if he can locate it.
    When looking for an after market replacement make sure you get an AGM battery, not just a flooded lead/Acid which are considerably cheaper. The experience seems to be that to find an after market that is equal to the Toyota is harder to find due to the limited amount of after markets that meet that criteria. And sometimes after markets are not cheaper.
  18. Mebeksis
    53
    17
    Covington, GA
    Is there any reason at all this battery wouldn't work? I got it because it was very similar in size to the old battery, it wasn't until I was about to put it in that I noticed the difference in CCA, which is where I posted on here last night about the difference. I don't want to put the wrong battery in and risk shorting it out or something like that. 20180703_230910.jpeg
  19. Mebeksis
    53
    17
    Covington, GA
  20. Mebeksis
    53
    17
    Covington, GA
