Car starting
Discussion in 'Gen 2 Prius Main Forum' started by Mebeksis, Jul 3, 2018.
  1. bisco
    52,730
    i doubt strapping down the battery does anything except keep it from getting damaged, as long as all the connections are tight.
  2. Mebeksis
    Mebeksis Junior Member
    53
    17
    Covington, GA
    And even when the dashboard display goes dark, the car still drives.
  3. Mebeksis
    53
    17
    Covington, GA
  4. Mebeksis
    53
    17
    Covington, GA
    because there's about a good 2 in around the battery for it to move around and shift if the the bracket and strap isn't holding it in
  5. bisco
    52,730
    that is what i meant, damage to the battery from moving around and bouncing over bumps. if the connections are tight, it wouldn't affect anything else.
    yes, you can drive the car without a working mid, you just don't get the info feedback.
  6. Mebeksis
    53
    17
    Covington, GA
    The tight thing is what I'm worried about. There's not a lot of slack in the cable at all, I was actually a little hesitant about that
  7. Mebeksis
    53
    17
    Covington, GA
    Give me a minute, I'll take a picture of it and show you what I mean.
  8. Mebeksis
    53
    17
    Covington, GA
    The wiring harness doesn't have very much slack at all, before it even splits off to the three plugs 20180714_122602.jpeg
  9. bisco
    52,730
    if you found something loose, that could wiggle from battery movement, that could cause problems.
    let's see how she does with the correct tray.
    jerrymildred likes this.
  10. Mebeksis
    53
    17
    Covington, GA
  11. bisco
    52,730
    ah, drive carefully.:)
