Car starts but dies as soon as you go into Drive
Discussion in 'Gen 2 Prius Main Forum' started by randall copeland, Aug 26, 2019.
  1. randall copeland
    randall copeland New Member
    itah
    So i posted a little bit ago with problems. It sounded like it was a inverter pump. I got a new one and put it in. The car started and ran. 2 weeks later im driving and lose all acceleration. I stop and turn of the car. When i start it back up the car stays on in idle. Engine is on and everything, but when i press the gas nothing.when i put it in drive it dies right away. Anyone else have this problem. I have a 2006 prius. I dont know if this mattets but i did run out of gas a week or so ago. My cluster is out so sometimes i miss the gas. The car is full on gas now so that is fine. Thank You for any help.
  2. PriusCamper
    PriusCamper Senior Member
    11,119
    4,527
    Pacific Northwest, USA
    There should be error codes that have been stored... An auto parts store can read them for you... Or you can install an OBD2reader and use Dr. Prius App to see some, but not all of the error codes. Learn more here: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Skibob and SFO like this.
  3. randall copeland
    itah
    ok guys i got my code reader in. p3190 and p3193. both said no dtc found. p0138 said oxygen sensor circuit high voltage. the last one was p0171 bank 1 to lean
    49,572
    what reader?
  5. randall copeland
    itah
  6. JC91006
    16,488
    8,402
    Try cleaning your throttle body and maf sensor.
    P3190 poor engine power is bad news, if it's not charging your hv battery, it can drain and not start the engine. I'm guessing you're probably at 1 bar remaining on your hv battery SOC
    #6 JC91006, Aug 29, 2019
    Skibob, Raytheeagle and PriusCamper like this.
  7. randall copeland
    itah
    i will this weekend. i did see the list of problems it could be so im going to go down the list. those 2 were on it. Ill check the battery. dont know if its this true read that everytime i try to start it while the problem is there it will drain my hv battery.
  8. jerrymildred
    jerrymildred Senior Member
    11,518
    14,121
    Tampa, FL
    It's true. The HV cranks the engine. That takes energy.
    Skibob likes this.
  9. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    What do you think starts the engine? It’s not the 12v, it’s the traction battery (the big one). If it’s not recharging at all then it will get to a point where it can’t start the engine. Like JC asks, how many bars are left on the battery monitor? Does the arrow show power going to the battery at all?
    jerrymildred likes this.
  10. randall copeland
    itah
    i did have power to the 12v. i cleaned my ma sensor and TB. changed the 12v and air filter. not sure which one was the problem but the car drives now
    bisco, Skibob, SFO and 1 other person like this.
  11. bisco
    49,572
    well done!(y)
