Car Stopped After Oil Change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AmandaC, Jun 4, 2023.
  1. AmandaC
    AmandaC Junior Member
    17
    Washington DC
    Help!
    I got a routine oil change on Tuesday and after a mile or so after leaving my mechanic place the car stopped accelerating and all of the usual lights came on for the hybrid battery (triangle; VSC; check engine; Exclamation point in big circle). I had the car towed back to the mechanic (lost a day of because my car key was stolen from the exterior overnight drop - luckily I had a spare). They said now the car won't turn on at all and the code 3190 was showing. They told me to tow it to a Toyota dealership so they can diagnose. Toyota said the only thing they found were hybrid battery codes P3000 and P0A80 and no oil anywhere. They wanted $6000 for a new hybrid battery but I had to purchase another one from Green Bean Battery (please don't give me a hard time about getting a refurbished one - the current one is also from them and the five year warranty just ran out this year). I had to have it towed back to somewhere for GBB to change out the battery - they did that yesterday and now the hybrid battery codes have cleared but now it's showing a ton more other codes with the main one being 3191. The car does turn on but engine turns back off after like 5 seconds and all the those lights are back on. I am at my wits in with this car. I still think it has to do with the oil change somehow and am going to go back to where I had it towed (I only have street parking so I had to tow it to a shopping center) and check to see if the oil was overfilled. They also checked the 12v battery and he said it is low but now low enough where the engine wouldn't start.
    Has anyone else experienced this and any guidance?? Please help.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Only a mile from oil change place it died? Why not walk back there and tell them what happened and have them figure out what they did wrong?
    The car may sound like it started up normally but engine won't start even though it sounded like it did because hybrid cars start their engine differently. Not sure why the Toyota Stealership didn't go after the actual problem. Maybe you tried to start the car too many times and drained down the hybrid battery too far? It's easy to put a high voltage trickle charger and charge that battery pack up.
    Of course the criminals at the Toyota Stealership will lie to you and tell you its not possible because they want to scam you out of $6K. You need to take it to a real mechanic.
    More to the point go to Google and type this and read all the results so you know what everyone else did who had this problem:
  3. AmandaC
    17
    Washington DC
    The mechanic isn't in a great part of town - but in the city that's how it goes sometimes. I didn't restart it after stopped driving and I pulled over. They may have tried restarting it a bunch at the mechanic's and then at Toyota which maybe at that point it had been drained. I think they do that too to see if you'll just give up on it and try to trade your car in.
    I did check the oil - it is a little above the full dot. I just don't think it's a coincidence that it happened right after the oil change. I've had the refurbished battery go out a few times (but with the warranty who cares) and I know all of the typical symptoms for that and it wasn't showing any of those prior to this event. Oh the dealership also made some note on the report about how not all refurbished batteries are compatible with hybrids. I've been using a refurbished battery for the past five years so whatever. Also the moment I told them I wasn't using them to do the replacement they were like when can you get your car out of here.
    Also this mechanic is usually very good but they had my car all day "checking everything" when I don't believe that either. They also told me the 12v battery was good and it wasn't. So I got impatient after they had had it all day and told me I would need to take it to Toyota anyway.
    My plan is to have the mechanic check the oil and remove some of it and then check everywhere oil could have gotten and remove the air and engine filter they replaced to make sure nothing is behind there either. Then decide what to do from there.
    Thanks for the articles!
  4. AmandaC
    17
    Washington DC
    hard to see but the oil is past the full dot. I keep seeing that really it should be a little below the full dot for a Prius Gen 2.
  5. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    That's the classic no-start. It sounds like it starts and then quits, but it doesn't really. It is just cranking electrically, and then it gives up. The P3190 means "help engine can't start"
    You'll need to diagnose that soon- you only get so many start attempts before the hybrid battery runs out.
  6. AmandaC
    17
    Washington DC
    It already did - I had it replaced this weekend with another refurbished one because it's affordable. Now I'm getting P3191 at the main code. I'm convinced it's something from the oil change. My plan is to take it back to the mechanic and explain that I checked the oil myself and that it is past full and that I want everything checked for oil etc. Toyota said they didn't see evidence of that however I don't think they looked very hard. This has been such a stressful hassle.
  7. JC91006
    16,936
    8,647
    Overfill
    AmandaC likes this.
  8. AmandaC
    17
    Washington DC
  9. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    I've had my generation to overfilled quite a few times what I would consider to be close to dangerously overfilled and it didn't hurt a thing this was in a car that was using oil so it would I would routinely overfill it a little bit once or twice I did it dangerously too full but the car ran fine didn't give me any props like a real long time for the light to come back on again those couple of times that I did that whereas normally if I would fill it correctly about four tank fulls going around the corner the triangle would come on and then soon as I write the car light would go out I knew immediately it was oil and when I got to my next stop there's oil in the trunk I just top it off another four four and a half tankfuls of gas same thing again which it 300 K is not too bad
  10. PriusCamper
    13,465
    5,431
    Might want to let your mechanic know about the threads on here that will them with diagnosis. Just tell 'em to "Google Prius P3190 after oil change"
  11. AmandaC
    17
    Washington DC
    I gave them a lengthy list of things I wanted them to check and Green Bean Battery had instructions for me to pass along as well. Their warranty department sent me a really thorough email about it. They said whenever there is an engine issue/code - do not try to start the vehicle until the issue is diagnosed because it will kill/drain the hybrid battery. They also said in this case to not disconnect the 12v battery bc it will do the same. They've had the call all day so who knows if I will hear an update today or not.
    What a headache!!
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I know exactly what happened. It was overfilled by a quart because that's what the universal Alldata book shows for the Gen2 prius.
    Seen hundreds of Jiffy Lube joints overfilling this car they use the same book.
    Alldata book shows 5 quarts for a G2 its actually 4. The G3 with the bigger motor takes 5.
    So the oil fouls the engine then throws 3191 engine wont start code but you keep trying to start it. But the problem there is every time you attempt a start it puts big load on the hybrid battery. The hybrid battery via Mg1 turns the engine over. Every failed start attempt is a very big current draw on the hybrid battery. Till the hybrid battery failed.
    That hybrid battery was probably not in the best of shape but this big no start load killed it. So yeah the over fill killed the battery.
    When the engine wont start on a G2 its tik toc. You only have a handful of start attempts on an old battery. You would have seen whats going on if you closely monitored the battery consumption meter during the start attempts.
    BrokenPipe likes this.
  13. AmandaC
    17
    Washington DC
    So then oil must have gotten on/in something right? I reached out to a prius mechanic and they said to also tell them to have the Mass Air Flow sensor cleaned. I just don't think this is a coincidence that this happened right after an oil change. I also keep reading in all of my research that a Gen 2 Prius only really needs like 3.6 quarts of oil but the full is 3.9. This is all so frustrating. I have loved my Prius since I've had it for a very long and time and it's been very reliable (only two times has it left me on the side of the road - this time is included in that number) but I'm ready to move onto something else at this point if I have to now worry about it being overfilled with oil and how much damage that causes...
  14. prius_deep
    prius_deep Member
    105
    38
    road
    read the dip stick again, looks like your car has no oil! it looks like what you think is over fill is just the splashing of what little it does have onto the dip stick.
  15. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
  16. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Assuming that there isn't a fault with something like the fuel pump doesn't work, then a common cause of a "no start" on a Prius is carbon-goop deposits built up in the throttle body bore.
    The build up restricts airflow at idle speeds, so the ECM opens the throttle slightly more to compensate, and stores this in memory. At some point the ECM can't compensate enough, (or something happens to the 12V battery and the ECM resets throttle back to "factory" specs.) Either way the engine doesn't get enough air to start.
    The fix is to remove the air filter housing and clean the throttle blade and bore. (I use a little bit of spray throttle cleaner - or brake clean - with an old toothbrush and a rag).
    Also not a bad idea to carefully clean the sensing elements down inside the MAF sensor.
  17. AmandaC
    17
    Washington DC
    OK I just spoke with the mechanic because I wanted to share the info sheet from the battery company on ways to not kill the new battery plus they gave a list of things to check when these codes come up (which would have been helpful when I first called them to let them know what code was coming up)
    The mechanic said gas is not going into the engine but he is waiting on a tool he needs to be able to check something for it which should arrive tomorrow. Would that be a fuel pump issue? He said when they manually force gas to the engine - the car runs perfect but it's not doing it on it's own. Also I am going to call Toyota corporate and let them know their service center did not properly diagnosis my vehicle and if anything can be done for that.
    Could this still have been caused by an overfill of oil? Thanks everyone for your thoughts.
  18. bisco
    52,855
    i don't think so. it could be a fuel pump failure, or one of a few other things
  19. AmandaC
    17
    Washington DC
    OK update - it does appear to be the fuel pump. I have never run out of gas in my life but it was explained to me that if the fuel pump is bad then the gas meter won't accurately show how much gas is in the car. When I took it for the oil change - there were two bars of gas showing. The mechanic put gas in it and the car worked fine. He was short staffed today so he could not take it on a longer drive so he is going to do that tomorrow to see how it does. I also spoke with the GBB warranty manager who was a mechanic for a long time and he said that will happen if the car runs out of gas (all of the lights coming on etc etc). Prior to that he did spend like half an hour on the phone with me explaining everything and what the possible options for the repair could be. Will post another update as I know more.
  20. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    This is days ago, but I bought a new 07 and it had one mile on it for the initial test drive. The oil level was exactly like you show, slightly over, from the factory. The oil looks like you have kept it up in changes. It wasn’t the oil level. Others have said the same thing when they got the car new, slightly over the full line.
