car stopped running, 4 codes pulled
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Jan 8, 2014.
  1. salguod
    salguod Member
    234
    37
    Columbus, OH
    Multiple pricey problems changes the situation significantly.
  2. JC91006
    16,876
    8,619
    There really aren't too many problems currently on the car, however with that mileage, it's eventually going to start. This would be a no brainer to fix if the traction battery was still under warranty, one less problem to worry about.
  3. JC91006
    16,876
    8,619
    I was looking around craigslist for parts and asked this person that's parting out a car for his transmission. He said was willing to sell the transmission for $400 and install for $300 more. I don't think that's a bad deal. $700 to get this thing running again.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    $700 for a transmission install? That's a deal. I would take him up on it!
    Even if you simply sell the car afterwards, the $700 will be offset by the increase in the sale price compared to a non-running vehicle.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Also JC91006, you shouldn't just assume that the traction battery will self destruct or something at a given age or a given mileage (like 10 years or 150000 miles for example). The best predictor of a battery's future state of health is its current state of health, not its age, and not its mileage either.
  6. Patrick Wong
    18,210
    6,514
    I agree that the traction battery's ultimate service life cannot be easily quantified, as there appears to be a very wide range of actual outcomes.
    However I do not understand how uart would translate "current state of health" to a prediction of future state of health. There typically are no advance warnings given when the traction battery ECU decides to log a DTC. One day the Prius is working fine, the next the dashboard looks like a Christmas tree and driveability is significantly impaired.
    In any event, I think that 2G traction battery failure is not a big deal for owners who can provide DIY labor on the replacement and can source a battery from a salvage yard, etc. This is primarily a big deal for owners who have to depend on Toyota dealer service and installation of new parts.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Let me explain what I mean. If you were really worried about the likely remaining longevity of your traction battery, then I say the best thing is to actually look at the module voltages, amp hours and internal resistance. There are a lot of devices/software that can do that these days, including now a relatively cheap "stand alone" obd2 device. That info is a way better predictor of remaining longevity than either age or mileage.
  8. JC91006
    16,876
    8,619
    I'm still debating on getting this fixed. There are no guarantees to this transmission, although I did check the records running the VIN#, the car was totaled at 60,000 miles so the transmission has low mileage. This would strictly be for my friend still, I told him I didn't need another car and I would help him get it running again if he wishes. If I were to buy it for $1000 as he offered, I would use it as parts for my 06 and 08.
    I know the traction battery isn't a huge issue but I still don't want to deal with car problems. I just like to drive them and do simple DIY, I don't want something I have to work on constantly out of necessity.
    Patrick, if you read this, here's a question for you, regarding your 2004.
    I know you keep your cars maintained at a very high standard and they can travel anywhere cross country without any problems. Now that your 2004 has reached over 150k and nearing 10 years, do you still have that belief that you can go cross country with no worries with this vehicle? Or would you swap out your 2004 traction battery before it fails as a maintenance item with a lower year/mileage one from a salvage yard?
    My thinking is if this car with 152k miles is to get another transmission, I may go through with a battery swap as well. The working traction battery in the car now with 152k shouldn't be hard to sell and I would feel better with a newer traction battery and transmission.
  9. JC91006
    16,876
    8,619
    Uart,
    I may be over reacting to the battery issue. I read these threads and it's not always a good thing. People normally come on here with problems and that's why I read about. All the failures so far are fairly close to when the warranty expires. You can't deny that's a weak point in the Prius.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    The problem is that you don't know the underlying numbers (population) to deduce any reliable statistics from that anecdotal data.
    What is the failure rate per year for batteries at around 150k miles. Is it 1 in 10 (per year), 1 in 100, 1 in 1000 - you tell me. With all of your anecdotal data can you even tell me to the nearest factor of 10 what are the true underlying statistics?
  11. JC91006
    16,876
    8,619
    You are correct, I don't have the necessary data to back up. It could go way beyond 150k, there is no telling with the current information available. The guy that just bought his $2200 2004 with 180k seems to have an original battery. So I might just be paranoid.
  12. Patrick Wong
    18,210
    6,514
    An excellent question. I certainly can understand and appreciate the thinking of an owner who decided to perform a preventive replacement of the traction battery due to age and mileage.
    The 2004 currently has 165K miles and is 10 years old. The car is our daily driver and logs ~25K miles per year due to frequent road trips.
    For fun and so that I can eventually post in the 200K mile owners sticky thread, my wife and I have decided that we will try to log at least 200K miles on the 2004 before letting it go. That will be the most miles we have logged on any vehicle.
    I have thought about whether I should do a preventive replacement of the 2004's traction battery. The 2001 Prius and 2006 HiHy both had their traction batteries replaced under warranty, so I have first-hand experience regarding traction battery failures.
    I decided that I will accept the risk of seeing whether the 2004's original equipment traction battery will last during our ownership period. However I carry tools in the car so that I can disconnect the 12V battery if necessary.
    That will enable me to deal with high voltage ground fault issues and minor battery module imbalance issues, simply by clearing the DTC temporarily. The car will function until the DTC is logged again and the car turned off. Depending upon the DTC, the hybrid vehicle ECU may not allow the car to become READY again - hence requiring this workaround.
    Hopefully the workaround will give me sufficient limp home range so I can get the 2004 home if necessary. If not, then I'll get to pay big bucks for an emergency traction battery replacement out in the middle of nowhere...
  13. JC91006
    16,876
    8,619
    I learned quite a valuable lesson from that statement you have about doing maintenance at a time of "your" choosing instead of when the car fails. I never thought about car maintenance like that, only applied that thinking to replacing 12v batteries. But it should be applied across the board.
    If you are going to take this gamble in getting your car to 200k, maybe you should go a AAA membership that will allow you to get a 100 or 200 mile emergency tow. You should be able to surpass 200k within 2 years and it would just be added security to have that tow available.
  14. Patrick Wong
    18,210
    6,514
    As a matter of fact, we do have the AAA family membership with extended towing... Thanks for the suggestion!
  15. Salvage09
    Salvage09 Junior Member
    38
    Pasadena CA
    Did you check the 12 v battery voltage? When the 12 v battery dies, you get all kinds of weird codes that all go away when it has enough juice. Look on priuschat how to check 12 v battery voltage.
  16. JC91006
    16,876
    8,619
    The end result of this thread ended up with the transaxle being replaced. It wasn't the 12v that caused the DTCs.
  17. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Old Priuses seem to have a design flaw, where a part of the motor generator 2 is located in a place where oil can't reach it, overtime it burns and the motor won't work the way it was designed to work, and later on it will fail.
