Car Talk Prius Question Not Really Answered
Discussion in 'Gen 2 Prius Technical Discussion' started by TonyPSchaefer, May 17, 2009.
  1. TonyPSchaefer
    14,816
    2,502
    66
    Far-North Chicagoland
    I sit here corrected. At lunch when I checked, I must have not seen the indicator due to the sun. In the evening, I decided to check again and sure enough you were correct: the light indicator is still illuminated even after I powered down the car.
    During lunch, I was able to turn the lights off using the steering wheel stick and then turn them back on. All without opening the driver's door. I didn't think to test that this evening to see that the indicator would go off and then on again. But I'm suspecting that it would.
  2. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Right after purchasing my Prius, I went to Walmart and bought the Black & Decker "Start It" model VEC012CBD. After reading about the lack of "foolproof" design in the Prius' 12v power management, I figured that I should have some "insurance", in case we ever managed to drain the 12v battery. Also, I'm used to carrying a tire inflator around with me. This unit handles both duties. I've attached a picture.
    Interestingly, the only time that I've used it was to jump a dead battery in my minivan. It did that without breaking a sweat, and still has almost a full charge left! Nice unit.
    Best wishes,
  3. tochatihu
    tochatihu Senior Member
    9,997
    3,862
    Kunming Yunnan China
    2001 Prius
    David makes a good point about corroded connectors in the 12 volt system. Something we all might consider looking at, because it makes the Prius' little battery even littler.
  4. daniel
    14,487
    1,519
    Spokane, WA
    It's entirely possible that the woman, being in need of a nap, didn't notice the headlight icon.
  5. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    '07's have the icon on the dash
  6. Politburo
    Politburo Active Member
    971
    208
    I'm not sure I understand what setting is being changed here. AFAIK, on the US models the car doesn't care when you turn the lights on.. the behavior is the same.
  7. bwilson4web
    16,549
    I finally listened to the podcast and the owner has a 2007 and everything points to the auxiliary battery draining while parked. It may be a little early but their advice was to go to the dealer. Problem solved.
    Now if the owner ever wanders here, we can give her advice on getting some heavier duty, replacement batteries. I believe good Prius friend Hobbit did the Omega battery replacement.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I took the liberty of submitting this entire thread to Car Talk...let's see if they use it.
  9. efusco
    19,891
    1,196
    Nixa, MO
    Looks like Beteljuice posted there
    Car Talk - Why won't Elsie's Prius won't start after naps
    I got the following reply from the Car Talk staff:
    Thanks. I've passed it along to Tom and Ray. There's also a reference to your chat here:
    Thanks for sharing. They'll be interested to see this.
    Best,
    Doug Mayer
    Car Talk
    (and happy Prius owner)
  10. TonyPSchaefer
    14,816
    2,502
    66
    Elsie wrote back. She had come to the same conclusion as we did.
  11. daniel
    14,487
    1,519
    Spokane, WA
    Woo-hoo!!! I was right! :cheer2: :rockon:
  12. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    Was it ever in doubt? ;)
