Car thinks fob is in the ignition overnight, now won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by barbie.gee, Nov 13, 2012.
  1. Patrick Wong
    18,210
    6,510
    Once you get the Prius started then it should continue to run without a problem - unless your 12V battery is in such bad shape, with one or more shorted cells, that it loads down the 12V bus to the point where a fuse blows.
    [email protected] likes this.
  2. barbie.gee
    barbie.gee Junior Member
    70
    Chicago, IL
    Here's how this all turned out... I was able to get a jump start afterall (the parking garage has that service), and drove the car to a dealership about 4 miles away. They listened to my fascinating story, and then promptly just tested the battery with the car running, and then again with the car turned off. The battery tested bad, with a bad cell. I have the little print out of the test result if anyone's interested. So, $350 later, I now have an official Toyota 12v battery installed, and the Exide is sitting in the back, waiting for me to call the place I bought it from for a refund. I wonder what they'll give me for it... I still need to see if the car starts this morning, but I've got a feeling they called it right. I'm really disappointed that the Exide was a flop, though. Doesn't build confidence in going with a non-Toyota replacement, but I could just be the one-in-a-million outlier.
    Thank you everyone for your help and advice!
    (And I'll be back here if the car won't start later today!)
    koolingit likes this.
  3. John H
    John H Senior Member
    2,208
    558
    Glad to hear that the issue with the 12 Battery is resolved.
    I would expect the Exide battery warranty to be a replacement rather than a refund. IMO, the dealership should have recommended that you have the Exide battery replaced under warranty rather than sell you their battery for $350.
  4. richard schumacher
    7,664
    1,046
    United States
    Was the $350 just for battery and installation, or did that include a diagnostic fee?
  5. barbie.gee
    70
    Chicago, IL
    $350 for everything.
    Highway robbery, but it's a dealership.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Hi Barb,
    Just for grins, would you please post what your voltages are running the test that everyone recommends here to check the 12 volt with the MFD? I would like to know what a "new" Toyota battery would show, and since you just put one in, you could tell me those figures. I am only interested in knowing what the acc and the ign-on mode's read. I don't need to know what it is with your Prius in "ready" mode. If you don't mind, please run the test after the car has sat for at least eight hours.
    Here is the routine in case you are not sure what I am asking for.
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button, then turn the headlights on and off three times to enter Maintenance mode; release Info button
    - Press “Menu” (on screen)
    - Press “Display Check”
    - Press “Vehicle Signal Check” - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there may be a problem with the charging circuit)
    - Turn car OFF to leave Maintenance mode
    Good luck to you and I hope the new battery does the trick!
    Ron
  7. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    High Barb, sorry to learn of your troubles with the Exide battery, particularly as I recommended this battery.
    But I do not understand how the dealer can properly have tested the battery when we know it was fully discharged "way past the normal discharge limit" then charged by the car for a distance of 4 miles say 15 mins at 4 amp charge "the maximum rate for the Prius".
    That gives a charge into the battery of 1 amp/hr into a 45 amp/hr battery. This amount of charge would not even bring the battery into it's normal minimum charge state "10.5 volts". Any battery tested in this condition is going to show up as bad and we all know the dealers have a reputation for being unable to tests 12 volt batteries and give meaningful results.
    I agree with John Hatchett in post 23 that Exide should have had the chance to check and replace the battery if it is faulty, but also understand the position of needing to use the car at that time, catch 22. I feel that Exide will replace this battery if it is proved to be faulty but doubt "hope I'm proved wrong" they will give you a refund.
    John (Britprius)
  8. richard schumacher
    7,664
    1,046
    United States
    For a dealer $350 was not too bad. The battery alone is $180, labor for it is commonly $50, and the diagnostic fee is commonly $100.
    4 Amps is the right charging rate for the battery but it would need hours to charge, not 15 minutes.
