Car Wash and putting car in Neutral
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Dec 11, 2017.
Tags:
  1. Mark57
    2,945
    2,740
    OK
    Same here. I've used a track wash 3 times now. It takes 30 seconds to cycle through and turn off all the "gripy" sensors. Throw it in neutral and get clean. Turn them back on after the dry down. No dead batteries, no griping sensors, just a clean car.
    This is just not a big deal.
  2. Matthew Cook
    Matthew Cook New Member
    Atlanta GA
    I have two Prius’. One is a 2007 and one is a 2011. Both have had the problems of the battery dying in the car wash when having it in neutral. Now I only go to the car wash that has the drive in a park and touchless sprayer. Not as good of a wash but it was sure scary when both vehicles turned off and I had trouble getting them started again. I’d avoid these track style car wash places.
  3. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    I don't have an issue now when I put in neutral at the car wash, I just temporarily disable the sensors function in the menu. :)
    Merkey likes this.
  4. GoneTooFar
    GoneTooFar New Member
    Ohio
    2019 Prius
    XLE AWD-e
    I disable PKSB and PCS and it still beeps all the way through the car wash.
    What else do I have to disable to make it stop?
  5. Northerner
    Northerner Active Member
    121
    103
    Midwest
    2020 Prius Prime
    Glad this came up as I failed miserably at this today. I thought I shifted into neutral but must have done something wrong. The car moved into the car wash faster than the track wanted it to. I got the “Break!” signal and so hit the breaks and tried for neutral again. In the flurry of beeping and flashing alarms - I wasn’t sure what was moving me through the wash. I was breaking and letting my foot off the break at a fast pace that felt OK, still trying to shift to neutral, but it didn’t feel quite right. Somehow the car came through clean and without damage - but I was angry at myself for thinking I could figure it out on the fly.... again. (2020 Prime Limited)
  6. GoneTooFar
    Ohio
    2019 Prius
    XLE AWD-e
    You have to hold the shifter in the neutral position for a beat before it'll take.
    I usually pull over before I get in line for the car wash to make sure I have time to disable PKSB and PCS ... but doing that doesn't stop the beeping, so what else do I have to do?
  7. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Or double-tap the shifter into N.
    Let it beep. It's not a problem. A couple of years ago certain washes would activate the brakes on certain Primes. A software upgrade from the dealership fixed that. My 2017 Prime never had a problem in the wash. Hold the shifter in N for a second, let it go, let the chain pull the car through the Tunnel o' Suds. Let it beep. At the end when the green light flashes shift to D and drive out.
    pghyndman likes this.
  8. KH111
    KH111 Member
    65
    37
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I failed the car wash test recently for the 2nd time. First time I struggled getting it into "N" and the moving roller lifted the car twice as it slid under the left front wheel before I successfully selected neutral. Of course the car wash guys yelled at me and pointed to the sign that said put your car in neutral. After practicing with the shift lever a few times I went back to the car wash (months later), proudly pulled up and into the guard rails and confidently placed the car in neutral. Unfortunately I had forgotten that I had used the "HOLD" function of the parking brake ( a switch on the console, park brake activates after using the brakes to come to a stop) earlier so once again the car bounced up and down as the roller passed me by. I finally figured it out, depressed the switch, brakes released and the car moved smoothly down the track. I find it too cumbersome to turn off the collision warning sensors so just have to listen to the various warnings through the tunnel. No issues with the brakes automatically applying anywhere along the way.
    KH
  9. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    The Carista app can enable a setting to automatically disable all the beeping when in Neutral. Great for going through car washes.
    frederw1701 likes this.
  10. frederw1701
    frederw1701 Junior Member
    50
    16
    WA
    2018 Prius Prime
    If a 12V battery goes flat when going through a car wash, does that mean it was at death's door when it went in?
  11. ChapmanF
    18,215
    If the 12 volt battery in a Prius ever goes flat sitting in neutral with the hybrid system READY, there are bigger problems than the 12 volt battery. Either the car's DC/DC converter isn't working, or the traction battery went flat first.
    frederw1701 and Brian1954 like this.
