Car will not reverse.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RajivR74, May 23, 2019.
  1. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    So I just drove the car on the street & within one mile, the car went into limp mode with the 'Check hybrid system' message & threw code P0a94. I think it's posessed!
    52,849
    see if there is movement in the inverter coolant reservoir
    RajivR74 likes this.
  3. RajivR74
    37
    Horn Lake, MS
    It looks like it's moving, but it could just be the vibration from the car. I can definitely see when the coolant is moving in the reservoir of my 2005 2nd gen.
    52,849
    easier when the engine shuts down
    CR94, RajivR74 and Mendel Leisk like this.
  5. Mendel Leisk
    42,345
    Don't dismiss any more codes.
  6. RajivR74
    37
    Horn Lake, MS
    I do see movement of the coolant with the engine shut down & the car in ready mode.
  7. RajivR74
    37
    Horn Lake, MS
    I take a screenshot of every code(s) that pops up. I have to delete the codes in order to get rid of the 'Check hybrid system' message.
  8. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    Torque app may not be showing you everything. You might want to find a more Prius-friendly diagnostic tool. Techstream is the gold standard.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Have the IPM software updates been done?
    Sounds like the inverter May have given up the ghost.
  10. RajivR74
    37
    Horn Lake, MS
    I looked into Techstream & there's all kinds of options out there. Are they all the same or some counterfeit? Does it make a difference?
  11. RajivR74
    37
    Horn Lake, MS
    I don't think any software updates were done. At least not since my friend owned it. What ghost? Sorry I don't know what you mean.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    The P0A94 is the code for the inverter;).
    And when this displays, it can mean ther inverter is bad:(.
    The Gen3 has 2 software updates that were to help prevent this, and there is also an extended warranty on the inverter due to the failure condition:).
    Worth looking into a bit further(y).
    RajivR74 and Grit like this.
  13. ChapmanF
    19,020
    P0A94 refers to the DC/DC converter. That is located inside the inverter/converter assembly, and if it's gone south you'll probably end up replacing the whole assembly, true enough. But the converter is not the same as the IPMs (which are also in that same assembly), and if it was going to break, the IPM firmware updates wouldn't have stopped it.
    RajivR74 and CR94 like this.
  14. RajivR74
    37
    Horn Lake, MS
    I located a used inverter. The model number is G9200-47161 but the one on the car is G9200-47210. Will it work? Thanks for all the input guys!
  15. RajivR74
    37
    Horn Lake, MS
    I called the dealership with the vin number about the inverter & they informed me that the software updates were performed this February of 2019 but there was no active recall on the inverter itself.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  17. RajivR74
    37
    Horn Lake, MS
    Apparently this is a much bigger problem than what a software update will fix. In fact, it seems like the software bandaid speeds up the burn!
    THE DEFECTIVE TOYOTA PRIUS HYBRID INVERTER | ToyotaTalk
  18. RajivR74
    37
    Horn Lake, MS
    This is the inverter converter that I purchased on ebay. It came out of a Prius V. The seller assured me that it will work on the Prius. Will it? The model of inverter converter that's originally in the car is G9200-47210 (pictured here) with the big 'K'. The inverter converter from the Prius V that I purchased (also pictured here) bears the model number G9200-47161 with the big 'B'. Thank you for all your help and input! 20190526_125030.jpeg CYMERA_20190526_145446.jpeg CYMERA_20190526_145554.jpeg CYMERA_20190526_145615.jpeg CYMERA_20190526_145642.jpeg CYMERA_20190526_145707.jpeg
