Car will not turn on after battery replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priushelp2018, Jul 2, 2018.
  1. priushelp2018
    priushelp2018 New Member
    Phoenix Arizona
    Good evening I am new here but the reason to joining is based on a problem I have on my 2007 toyota prius I recently replaced the 12V battery but now the car is not turning on there is current because the Lights turn on but the car does not turn on the instrument cluster does not turn on aswell doors wont unlock or lock with the key or with the buttons when I try to turn on the instrument cluster displays check engine nothing else but when I connect the OBD reader it does not turn on aswell. I have tested the battery and it seems well. I would appreciate some Ideas thank you
  2. Dbryant1732
    Dbryant1732 Junior Member
    40
    Clarksville, TN
    I would try unhooking the battery for at least 10 mins and try hooking it back up to reset the CPU. That is what I would do first.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Check all the mechanical connections around the battery: Terminals, ground and plugs.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Did you disconnect/reattach the two (2) connectors on the positive side of the 12v battery?
    ITBland and Raytheeagle like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    May I ask what lead you to replace the 12v battery? What symptoms were you experiencing that caused you to believe the 12v battery needed to be replaced?
    Are you sure the "check engine" is displayed, or is it the "car symbol with a key inside it" flashing?
    The "check engine" is actually an outline of a car engine with the word "check" underneath it.
    #5 TMR-JWAP, Jul 3, 2018
    kenoarto likes this.
  6. kentmitch
    kentmitch Junior Member
    38
    16
    Kansas
    I read recently that you open and close driver's door and wait 10 seconds before trying to start. Don't recall where I read that or whether it works but simple to try. hope this helps
    Also you'll need to reprogram the window button and tire pressure monitor as I recall.
  7. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Must have started working again?
  8. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    It was supposed to be 114F in Phoenix today, maybe they don't dare go outside to look at it?
  9. JC91006
    16,871
    8,619
    If you touch the orange interlock disconnect on the hv battery, you will have to reseat it before the car will start
