Car won’t start, only check engine light on
Discussion in 'Gen 2 Prius Technical Discussion' started by AVS1, Nov 23, 2018.
  1. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    While technically correct, it is more like dipping down to 9V - 9.5V before you will see the master warning light (MWL) flash.
    I know this because I have wired in a voltmeter and observe my car dipping below 11V (typically 11.6V - 11.8V) on the initial startup and I never see the MWL flash at this high a voltage. (When I see the low voltage, though, I put my 12V battery on the charger at the next convenient opportunity.)
    Just for everyone's information.
    jerrymildred likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Same here and then some. My old 2005 got down under 9 volts. If I recall the exact number it was 8.7V. No MWL. The only sign something was amiss was that the brake accumulator was taking a very long time to make pressure when I got in the car to drive it.
