car won't shift out of park
Discussion in 'Prius c Technical Discussion' started by vinny1575, Jul 7, 2012.
  1. vinny1575
    vinny1575 Junior Member
    87
    Jacksonville, FL
    I was successfully able to install my Prius backup camera, but a few hours later I found that I could not shift out park. I was getting code U0293 on my scangauge. I can push the override button next to the shifter to shift out of park, but I can't figure out whats going on. Hopefully I can go to the dealer tomorrow.
  2. RRxing
    RRxing Senior Member
    2,520
    1,792
    NEPA
    This is for the 2010, but I'm sure the code is the same.
    BTW, your avatar says you have a 2006, but you posted in the c tech forum...
  3. vinny1575
    87
    Jacksonville, FL
    I have a prius c. I need to change that.
  4. vinny1575
    87
    Jacksonville, FL
    So the error has not returned, but there is still an issue. Has anyone seen this?
  5. vinny1575
    87
    Jacksonville, FL
    So I found the problem. I found the fuse box under the dash and the fuse labels "gauge" was blown. I replaced it and all is well. Bcakup camera is working.
    Surrylic likes this.
  6. Mik1
    Mik1 Member
    333
    Houston, TX
    It's good to know that everything worked out well for you, and it was just a fuse. Do you thing you have shortened something during the installation process?
  7. vinny1575
    87
    Jacksonville, FL
    yes definitely. Most likely the reverse power.
