Car won't shut off.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, Oct 21, 2018.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    For about a year now my combo meter has been going on and off. For a long time it stopped doing it but yesterday it finally died. No series of button pushes will shut the car off. I ended up pulling out the main 12 volt lead off the 12 volt battery to kill it.
    When it started doing it last year I bought a rebuilt meter off eBay so I had one in stock. They programmed my mileage into the module. I can fix the board but thought it would be easier and quicker to install the new board while the car was all torn apart.
    Its not a real bad job found out that most of the front part of the dash had already been removed and re-installed before when Best Buy installed a new pioneer car stereo 2 years ago. You have to pull out the MFD apparently to get to the radio which requires the whole front of the dash to come out.
    I used a real good You Tube of the dash disassembly as a guide. And as the you tube showed the hardest part was taking off the screw covers on the screws that hold the upper glove box. I found using a dental pick worked really good. Long steel stem with very small right angle at the end to grab the lip of the cover and pull it off.
    Scariest thing for me is unplugging and plugging the passenger side air bag connector. But 12 volt had been unplugged for quite a while so no issue.
    Took me about 3 hours R & R. If you know what your doing you could probably do it all in half that.
    VFerdman and Raytheeagle like this.
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Pull the four fuse under the hood driver side the ones car spaced apart in the fuse box top right. Then power car off then install them. it temporarily fixes the dash lights to
  3. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    Good work! So now you have less mileage showing on the odo? I thought the issue with the combo meter was a capacitor, which is really easy to replace. Or am I confusing it with the MFD?
    Enjoy!
    #3 VFerdman, Oct 21, 2018
    edthefox5 likes this.
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Heat on side with a fine tip soldering iron. Tip cap at the same time should move a tiny bit heat the other side tip to opposite direction should move a little bit more go back to the first side heat it should come off that side do the same thing to the other side then I would probably buy a capacitor with legs and may be use wires and just glue it somewhere out of the way making sure none of the legs touch anything besides the board the surface mount caps are really hard without special equipment especially to solder back on 20181021_072232.jpeg
    VFerdman likes this.
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    There two versions of that board too. match the display is
  7. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Thank but I already had the back hatch all opened up and its faster to just unclick and pull out the main 12 lead.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    No that's not how you remove smd caps. Just get a needle nose and gently rock the cap back and forth in the other direction of the 2 leads. Basically rocking across the leads. Snaps right off. Then clean up the pads.
    I see all these you tubes of tacking on an axial cap across an existing smd cap. That may work for a while but the existing smd cap your tacking onto thats still on the board has bad esr and will continue to have worse esr which means you have a resistor across your cap with changing value. Needless to say you will back in there again eventually to do it right.
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I said you move by heat one side at a time the tack one to those pads. With wires
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    yes when I bought the replacement board it didn't fail till a year later so yes I now have less mileage on the odometer about 9,000 miles less. new board shows 110,000 miles.
    And there's multiple caps on my old board that show esr. The replacement board I got had 4 caps replaced.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    If I had to guess the cap with the higher value do way more work then then there fail first.
    had a idea find the 12v going to that board cut the supply 12v wire line to that board and install a noise filter 12v 10 amp one to suppress all that noise
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    You may have more noise than a normal Prius has making it fail even if the Caps are good
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Not sure what your talking about. Its not a noise on the 12 volt buss issue its an old capacitors with esr issue. There's a switch mode power supply on that board. There's already a large cap hanging off the 12 in as a decoupler.
    If the 12 had excessive noise the switch mode would not work.
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Not sure what your talking about. This board lasted 11 years in a car.
  15. edthefox5
    10,096
    4,837
    Clearwater, Florida
    No you didn't you said to take the cap off:
  16. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Well your right but if you heat one side and tip it will lift the leg off a little each time. doing it on both side it well fall off. Sorry I wasn't clear or if you have tweezer soldering station just heat both sides at the same time and left it off. ( Removing the cap)
    Check your battery for AC should be less the . 0v but I had to add and 12v noise isolator to get my Bluetooth clear. The car change voltage alot 200volt to 12v to 5v then to charge the 12V has to make 14v the there 3 phase air conditioning DC to AC to DC again all make noise if you have a oscilloscope you can see all the noise. Or a 24v light and hook it to the 12v you can see the flicker (light has to be dim to see it. )
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I’m sure there’s some trash riding on the 12 volts but most circuits should be immune to it if properly decoupled. As far as our discussion on that trash affecting the combo meter I disagree. And it’s sure not hurting any other circuit in the car because we would be seeing all kinds of wonky ecu issues and we do not. This car is an amazing piece of engineering the design of the inverter is world class for its day.
    The combo is properly decoupled it’s a very well designed circuit and the caps that are failing are failing from old age.
    It’s survived 11+ years in my car in a very harsh environment. If you had to filter the 12 volts to get your Bluetooth device to work please tell me the make and model of that Bluetooth device because I find it very hard to believe you have to hang a capacitor across the b+ to make it work properly.
  18. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Noise isolator is a Transformer used for audio signals to isolate them from their source
    No display. Can't turn car off ect. Are not problems.
    The car reset most of the car circuits boards and sensor eveytime it turn off. So take longer to see them.
    If I was to add a capacitor 2 farad with a fuse relay cross the battery but I don't think my inverter leaking noise to that point
