Car won't start after minor cleaning/repairs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jbelsan, Aug 1, 2019.
  1. Jbelsan
    Jbelsan Junior Member
    Wichita, KS
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    The easiest thing would be to find or borrow a loaner OBD2 scanner (autoparts store) and read those stored codes (DTCs).
    If you have the four (4) DTCs, why not post them here?
    Did you forget to plug in the HV battery fan connector, or fail to properly install the orange HV disconnect switch?
    Raytheeagle likes this.
  3. Jbelsan
    Wichita, KS
    Car started fine after waiting around 15 minutes. Thank you for the response!
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    You probably have an old 12 volt battery and you left the doors open while working on the car and the battery almost died.
    Check it out because the last thing in the world you want is to be stranded from a dead 12 volt battery in a G2 Prius. That sometimes gets very very expensive.
