car wouldn't start
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Dec 15, 2022.
  1. misterdean
    misterdean Member
    204
    29
    FL
    i just got a portable air compressor and was putting air in my tires through the cigarette lighter while in accessory mode. i only ran it for about 5 minutes and then it started to sputter out. thought the compressor was junk but i noticed my door locks were acting strange. when i used the fob to unlock the front door would unlock but the rear would not. while looking at it from the inside i could see the rear lock kinda move like it was trying to unlock but it seemed really weak. my front locks were not right either usually when i press the button it's quick and crisp but it seemed sluggish. i tried to turn the car on and it would not start. alot of the service lights were on. triangle engine ABS etc. i turned the car off and tried again. this time the dash was freaking out. no service lights but the fuel gauge bars and and drive reverse neutral symbols were all flashing.
    this morning i got up to bring the battery to get tested and decided to try and start it. it started. no service lights. locks were working normally. drove the car to the shop. guy tests the battery. i see him look at the results like Wth. checked the connections and tested again. it says 11.57 volts and 0 cranking amps. i asked how the car started and runs with 0 cranking amps. he looked puzzled and asked another guy. he said the hybrid battery is probably helping it.
    i posted here a few months ago about it not starting. had a bunch of service lights on come on suddenly while driving. turned it off and would not start again. disconnected the battery and the car started. its been running fine for almost 3 months. not sure what to think at this point. the battery was bought new a few years ago and only has a few hundred miles on it. really curious what you guys think about 0 cranking amps. MPG currently around 47 so not quick to suspect typical hybrid battery failure but wondering if i could have an electrical problem.
  2. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Your technician hit the nail on the head it's reading zero amps and 11 some odd volts and if you tried to use that battery say to turn on a 12 volt light bulb I bet it would turn on and turn right off or something similar like there's no amps in the battery to move through the wire to light the filament in the bulb and then go back simple I think. It's time for a new 12 volt running a small slime air pump for 5 minutes should not render your battery not able to unlock the car. I'm assuming we're talking about readying the car because you're 12 volt battery doesn't start the engine It reads the car gets the computers up to snuff etc. The engine starting is done by the HV setup. So I'll assume we're talking about readying and then driving backing out whatever.
  3. misterdean
    misterdean Member
    204
    29
    FL
    not sure if i'm following you. i did not put the car in to ready mode and then try to start the car. i just started the car normally.
    Tombukt2 likes this.
  4. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    If this is true the battery is probably in poor shape. The car needs to be driven regularly to main a good charge in both batteries.
    As has been mentioned, the 12 V battery does not crank the engine, so does not need cold-cranking amps, just enough voltage and current to get the systems up and running. The HV (hybrid vehicle) battery then turns the engine over to start it.
  5. misterdean
    misterdean Member
    204
    29
    FL
    i usually drive it once a week. just not long distances.
    so is 0 cranking amps normal for a prius? trying to make up my mind between buying a trickle charger or a new battery. hesitant to buy a new battery cause i've been down this road before where people were suspecting the battery bought a new battery and turned out there was nothing wrong with the battery. given the milage on the battery makes me question it even more. i know you guys don't have a crystal ball but just want to hear some thoughts. if 0 cranking amps is normal thinking of just buying a charger.
  6. dolj
    dolj Senior Member
    8,631
    4,385
    No. Either your battery is needing to be replaced or the test was faulty.
    A few hundred miles over a few years is 3 ½ miles a day. That is not nearly enough to keep the 12 V battery charged.
    A good option for low miles is investing in a 4 or 5 A (forget a trickle charger) multistage automatic battery charger and connecting it to the car's 12 V battery any time the car is not being driven.
    #6 dolj, Dec 15, 2022
  7. bisco
    52,693
    generally, an auto parts store will charge it up for you and load test it for free to see if it is good, or needs to be replaced.
    have you checked to see if it is under warranty?
    either way, i would get a battery maintainer as dolj suggests above. you don't drive nearly enough.
  8. Tombukt2
    13,765
    2,491
    Durham NC
    You can't get the car to ready properly because you're 12 volts has 11 point something volts and 0 amps according to the person running the test so therefore you have barely enough juice in the battery to make the warning lights on the dash go crazy. Your mechanic or battery testing people told you this You wrote it in the previous group of text. So that's all I can go by I bet once you put a 12 volt in there that's new and has some cold cranking amps and is the proper voltage this problem is instantly gone.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    What you likely have is the battery tester couldn't compute a Cold Cranking Amps value with the voltage that low (my tester would read "voltage low - charge and retest"). Or your battery is just that weak.
    Get a maintenance charger or drive the car for a few hours each week.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,979
    924
    Southern California
    When the car was running the compressor was it in Ready mode and also in Park? If not all the power for the compressor came straight from the 12V battery, and that is not a very big battery on a Prius. So you ran that down. When you tried to start the car immediately the voltage/charge was too low. When a depleted lead acid battery sits for a long time with no load it can mysteriously "recover" somewhat. That is why when an attempt was made to start the car later it worked. Note that it only worked because all the battery had to do was power some electronics, it didn't need to spin a starter motor. The power for the equivalent of that on the Prius came from the HV battery, which was apparently in OK shape. You can recharge the 12V and test it. However, running one down to the point the car won't start is likely to damage it, so that it will not be able to store as much energy as before. Also, it may be old. Either way, you may want to replace that 12V battery.
    The 0 cranking amps result is probably just another way of saying that the tester employed refused to test it because the voltage was too low. Alternatively, it may mean the tester failed it immediately when the voltage crashed when a resistive load was applied.
  11. bisco
    52,693
    good point!
  12. misterdean
    misterdean Member
    204
    29
    FL
    when using compressor it was in ready and park. i had also used another compressor for 10 minutes about a week ago that also didn't seem to be getting the job done. same story. started strong and sputtered out. does it make a difference turning the car on when using the compressor? won't the engine just turn off? will the alternator run when the engine is off?
    he gave me a print out that actually said 0 cranking amps. they tested the battery while still in the car. how is the load test different? can it provide additional information about the battery?
    #12 misterdean, Dec 15, 2022
  13. mr_guy_mann
    4,109
    2,011
    NJ-USA
    There are two general categories of battery testers.
    First is the inductance - capacitance type. It has electronics to send a small AC voltage signal through the battery then uses some "mad science" to calculate the theoretical capacity. This test can work if the battery isn't fully charged - and it's easy - hook up the leads and push some buttons.
    Second is the resistive type. A big adjustable resistor is connected and used to load the battery while the voltage is monitored. Usually a load that's half of the battery's CCA rating for 15 seconds. If the voltage is above a minimum spec (which is dependant on the battery temperature), then it passes. Here the battery MUST be mostly / fully charged and some more skill required. This measures actual capacity.
    When done properly with good equipment, both tests are valid but aren't 100% foolproof.
    ColoradoCrow and bisco like this.
  14. misterdean
    misterdean Member
    204
    29
    FL
    should it make a difference turning the car on when using a compressor? won't the engine just turn off? will the alternator run when the engine is off?
  15. dolj
    dolj Senior Member
    8,631
    4,385
    Prii do not have an alternator.
    The inverter will supply both DC and AC power as required. It does not need the motor to be running except when it does.
    When using accessories like a tire compressor, it is advised to do that with the car in READY so that the 12 V is supplied by the inverter and also so that the engine can run as required to keep the hybrid vehicle (HV) battery at a good level of charge.
  16. bisco
    52,693
    it doesn't matter what order you do things in. plug in the compressor, make the car 'ready' or vice versa.
    whatever trouble you're having is either the 12v or the compressors, or something altogether different in the charging circuit or wiring
