Carbon buildup?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by njmurvin, Feb 18, 2012.
  1. njmurvin
    njmurvin Member
    103
    Simi Valley, CA
    I just had the oil changed today on my 2010 Prius IV. The last couple of services, the dealer claims I have carbon buildup and have pushed an EFI carbon cleaning service for $169. The car has 39K on it. Is this really necessary or is it snake oil to generate revenue for them? The car runs fine.
  2. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If his lips were moving when he said that, he was lying.
    srivenkat and Tande like this.
  3. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    Ask him to SHOW YOU the carbon, and that you want to verify it's existence, then watch him verbally "dance"......Save the money or enjoy a nice dinner !
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Tell them that you can pour in your own can of BG44K.
    Then ask how much they charge for a transaxle fluid change.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    ^ +1.
    Add a can of BG44k and Amsoil PI to clean out the fuel system. Then manually clean the throttle body with a can of throttle body cleaner. The injection of a solvent into the top-end of the engine for cleaning carbon has its benefits, but is probably not needed at the time. Still, if you really want it done, you can take it to Walmart TLE (gasp) and they will do their 2-step service (upper-end cleaner + in-tank additive) for $20.
    I also have begun using RLI Bio-Plus at every fill-up w/cheap fuel, in order to keep the fuel system clean. This solution is much cheaper than using plain top-tier fuel and subjectively, I've noticed a slight improvement in drivability.
  6. roth2006
    roth2006 New Member
    US
  7. Tande
    Tande Active Member
    553
    339
    Mich.
    LOL!!....:crazy:
  8. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    The BG44K AND Amsoil PI BOTH are really not necessary. Either would do. The Amsoil PI is excellent.
    Using RLI Bio-Plus at EVERY fill-up rather than top tier gas is more than overkill and completely unnecessary.
  9. richard schumacher
    7,683
    1,066
    United States
    If you usually buy E10 (10% ethanol fuel) the car has been getting all the engine cleaner it needs, and there is no carbon buildup.
  10. WE0H
    WE0H Senior Member
    3,247
    528
    A half tank of E85 will clean anything in the fuel system & combustion part of the motor. 50/50 gas/E85. I have run that in my daily driver for several thousand miles now.
    Mike
    iPhone :)
  11. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    With traditional cars, at 50K I check under the throttle butterfly where the EGR comes in, but always remove and clean at 100K. This car is a little different, so will look at it at 25K just to get an idea for myself. Yes, make them prove it needs it, if you are not a doityourselfer.
  12. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    For anyone thinking of trying this, you must not put in more than what Mike suggests, 1/2 tank. You will get lean burn trouble codes if too much E85 is present. The car will extend fuel trims (injector pulse width) by 20% to compensate for the lower volumetric energy density of fuel before setting a code. E85 has 30% less energy, so 1/2 a tank of E85 will lower the energy density by 15%.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    I bought an E85 converter for my Prii when I get it in May :)
    Mike
    iPhone :)
  14. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    With 106K miles I could eat off my tailpipe. Listen to PC
  15. WE0H
    WE0H Senior Member
    3,247
    528
    Taste tested, Prius Chat approved ;)
    Mike
    iPhone :)
  16. ETC(SS)
    7,514
    Gee.
    A consensus.
    How often does THAT happen in PC????
    Look. Here's the real deal.
    Check out your maintenance schedule. Does it call for a $169 dollar "Carbon Cleaning service"? No.
    It doesn't call for "A/C Refresh-o-matic" service either.
    Same goes for nitrogenating your tires.
    The next time somebody mentions "Carbon Buildup", tell them that you're already driving a Prius, and thus you're already doing your part to reduce carbon.
    Your car is running fine. If you have 170 bucks burning a hole in your pocket, spend it on something more useful, like lottery tickets.
    STOP GOING TO THAT DEALERSHIP.
    They're CROOKS.
    Additionally, I'd be tempted to fire off an angry inquiry to whatever Toyota has for a customer service branch in your area and demand to know why they're putting up with representatives of their company trying to fleece paying customers out of more of their money than need be spent on this vehicle for routine maintenance. :rolleyes:
    Good Luck!
  17. frodoz737
    4,795
    2,560
    33
    The cleaning, when required, is for the area directly behind the butterfly of the throttle valve to the intake valves (the intake system). The reason is EGR (exhaust gas recirculation). [ame]http://en.wikipedia.org/wiki/Exhaust_gas_recirculation[/ame] This is where the "carbon", as it's usually refereed to, comes from. It affects the surface flow, dimensional area, and sometimes free movement of the butterfly, together causing the fuel/air mix to be richer. This results in less complete burn, higher fuel usage and reduced life span of the catalytic converter.
    The affect and build up on the Prius should be less per mile because the engine runs less by comparison to conventional engines. It must however still be monitored and dealt with when evidence shows the need. As stated, I will check mine at 25K and every 25K there after before manually and chemically cleaning when needed. If the Dealer is trying to sell this service early, require proof first, then make sure they are not just adding crap to the fuel. Look under the butterfly before and after. Proper cleaning will require changing of the spark plugs as well. This has always been an up sale item, even though not usually required with conventional engined vehicles before 100K. There have been exceptions like VW TDI, which is problematic for heavy intake deposits, and a few others that require/d it sooner. I doubt seriously that the Prius will require this "service" at 30K, but will check mine on schedule to make sure. That's the long and short of it.
  18. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I agree except for the lottery ticket part. The OP should send any money he wants to throw away to me instead of buying lottery tickets. The end result for the OP will be the same either way, but if he sends the money to me, the joy of receiving his money will be within the PC community.:cheer2:
    lot·ter·y
    [lot-uh-ree]
    noun, plural -ter·ies. 1. A tax on the mathematically challenged.
  19. WE0H
    WE0H Senior Member
    3,247
    528
    It's also easy to take a spray bottle of E85 or some Iso-Heat and a toothbrush and scrub the inside of the throttlebody and idle the motor while you spray rinse the black goop with the spray bottle. The motor will suck the alcohol rinse in and burn it. You end up with a sparkling clean throttlebody :)
    Mike
    iPhone :)
  20. The Critic
    3,193
    2,333
    CA
    I meant OR. Oops.
    Generic fuel may not contain enough detergency to prevent carbon build up. Using RLI Bio-Plus will solve this problem.
    RLI Bio-Plus + generic fuel is significantly cheaper than top-tier fuel alone.
    MB860 ?
