Carbon buildup?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by njmurvin, Feb 18, 2012.
  1. Ffejrobins30
    Ffejrobins30 New Member
    23
    Santa Clarita, CA
    Looks like I'm going to be the thorn in the side here...
    A good EFI service is going to be required at some point. Due to the PCV system you are going to have carbon buildup on the throttle plate that will give you driveability concerns. This should not be the case at 50k though.
    As for the things where people say "it's not in the service schedule, therefore you shouldn't ever need it," think about this...
    Mass Air Flow sensors have a hot wire in them for sensing air flow, over time the hot wire builds up crap on it and reads less air entering the engine and you get lean codes. Every car out there that has a MAF has this problem. They should be routinely cleaned in order to prevent damage to it, but it's not in your service schedule. I clean them with every EFI service I sell. This just shows that there are thing you should do that may not be in a schedule.
    TsKarma likes this.
  2. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    I usually run a can of Seafoam every 10k miles on my other cars and on my Eclipse. Kept it running good, smoked a lot when put in through the brake booster but I did notice a lower idle. It would normally fluctuate from 800-1600 at idle but the sea foam helped stabilize it. I run it in the truck also with good results and thats only $10.99 a can
    Also have a can of MAF sensor cleaner and I do that every other oil change so every 10,000 miles.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Next time you go there, ask the dealer if he recommends a power steering flush.
  4. WE0H
    WE0H Senior Member
    3,247
    528
    Don't forget to top off the blinker fluid ;)
    Mike
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Are the muffler bearings sealed or do they need to be lubed too?
  6. WE0H
    WE0H Senior Member
    3,247
    528
    I suppose you could pop'a seal out'a there and squeeze sum grease in there ;)
    Mike
  7. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I had a car once without power steering, and when I'd get the oil changed at Jiffy Lube (I was young and didn't know better), they claimed they filled up the power steering fluid. I asked them to show me where they put it, and they said "oh, it doesn't have that it shouldn't be checked". In hindsight, that should have been a clue.....
  8. njmurvin
    njmurvin Member
    103
    Simi Valley, CA
    Thanks, all. I had a feeling that the dealer was doing an up-sell. My Dodge dealer has done likewise with my Ram 3500 (Diesel). You should read some of the the controversy surrounding transmission flushing (always suggested by the dealer) vs. drain, filter change and fill (recommended by the mfr). I tend to be skeptical of anything recommended that is not in the mfr recommended services.
    I have a can of MAF cleaner that I have left over from my BMW (I did eventually have to replace the MAF sensor at about 100K). I assume this cleaner would work to clean the Prius throttle body if needed? To get at it, do I just pull the air cleaner or is there more disassembly needed?
  9. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    Contrary to Ffjerobbins30 thread, use a bottle of Amsoil PI, or Techron in your gas tank twice a year and you'll NEVER need to even bother having to use your can of MAF cleaner.
    One of the Camry's in our fleet has gone 278K ( 2002 4banger )
    with normal maintenance, oil changes, filter changes, and the Amsoil
    PI 2-3 times a year and the MAF HAS NEVER BEEN TOUCHED, NOR has the car needed any kind of malarky "EFI" servicing.
    Relax ! It will be a long time, IF EVER, you will need to worry about your MAF or injection system. Save your money and buy yourself a nice cashmere sweater !!!
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    How does the cleaner in the gas get to the MAF sensor? I don't see the connection.
    Tom
  11. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Cleaning the throttle plate/bore/MAF is an every 60K or longer kind of service. It should be done by 100K. By 150K, if not done, there is the risk that too much carbon buildup will cause the plate to stick.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    Ran a tank of 4 gallons E85 blended with 6 gallons 87 octane and got 45 mpg with a 60 something mph average speed. The motor ran flawless, no codes :) I think the rental has a clean injection system now ;)
    I'll try a hotter E85 blend tomorrow :)
    Mike
  13. WE0H
    WE0H Senior Member
    3,247
    528
    6 gallons E85 & 4 gallons 87 octane in the rental Prii & she is liking it :) E85 is 60 cents a gallon cheeper than regular gas here in Indianapolis Indiana. Saving big $$$ and the Prii is not showing lower mpg's running it. I'll wait until I buy my own Prii before I try 100% E85.
    Mike
    iPhone :)
  14. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    While anything is possible, I am 99.9% sure that this will give you a code for lean burn.
  15. WE0H
    WE0H Senior Member
    3,247
    528
    Hope not but I will report back how she does tomorrow. I know the 1st Gen can run straight E85 with no problems. I bought a E85 converter to install in my Prii when I get it this spring. That will prevent any codes. This is my experiment in a bone stock rental Prii running a E85 blend. So far the experiment is working perfect. I bet the fuel system is super clean after running a couple thousand miles on my E85 blends :) Definately saving me some $$$ running it.
    Mike
    iPhone :)
  16. hashby
    hashby New Member
    I had the same problem yesterday. Also a 2010 Prius IV. The dealer claimed it was because of ethanol. He caught me off guard and I ponied up the $80. Now I don't trust the dealer to make an honest recommendation.
  17. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    They are all con artist.
  18. ETC(SS)
    7,515
    I'm kinda surprised that you're not seeing a little MPG ding in running E-40. I've switched back and forth from E0 to E10 and didn't see any observable difference, but I would think that you'd see a slight delta with your blend. Definitely not much to be sure.
    I'm curious as to which E85 Converter you bought, and how it works. Mind you, I'm not one of the George Noory types out there that thinks that ethanol is wrecking the planet, but the folks in Aichi have stated that you can't use E85 in their car.
    If you can buy a $200 widget (that they can probably buy for $25) that allows you to burn E85 in this car, then why don't they use the same technology and put yellow gas caps on the car from the factory???
    If the price delta is 60-cents now, what's it going to be when gas hits $5???
    Seems to me that either there's an underlying REASON that they don't want you to burn E85 in this motor, or they're missing an excellent opportunity to allow G3 owners to save even more money on fuel costs, which (environmental weenies notwithstanding) is why most people buy this car to begin with.
    Reader's Digest Version: I'd be very careful gambling a $25,000 car's health on a $200 Eth-O-lizer. Just sayin'! ;)
    Let us know how it works out!!!
  19. Former Member 68813
    3,524
    983
    US
    Only 45 MPG?
    Last time I did a long 60 MPH trip (due to foggy conditions) I got 56 MPG indicated. I also got 52 MPG on the return trip at 70 MPH. Relatively flat hwy.
    This is 87 octane Chevron "up to 10% ethanol" gas.
  20. WE0H
    WE0H Senior Member
    3,247
    528
    It was 10-25 degrees outside air temp. Cold driving in the northern states. The car had three people and a few hundred pounds of luggage & supplies.
    Mike
