Carbon in the engine
Discussion in 'Gen 2 Prius Main Forum' started by Benjamin13295, Aug 19, 2018.
  1. Benjamin13295
    Benjamin13295 Junior Member
    62
    Slovakia
    Is there anyway I can clean carbon deposits from my engine? Without damaging it?
  2. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    How did you confirm that there is carbon in the engine?
  3. Benjamin13295
    62
    Slovakia
    When they were replacing the chain they said there was allot of carbon and I should be replacing the oil more frequently, the previously owner didn’t take much care of the car , I replace the oil every 4K miles
  4. qettyz
    qettyz Active Member
    181
    208
    Finland
    There is all kind a engine oil flush fluids what do the job, but ive been told that after flush it is important to take oil pan out and clean it also. Flushing puts all the stuff moving and may do damage if all that stuff is not taken away.
    Benjamin13295 likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I use BG Products EPR before draining the oil to remove engine deposits. You can buy it on Amazon.
    Once the EPR is placed in the engine, run it for 10-15 minutes at idle, then drain it. The oil comes out jet black every time.
    This is using high quality oil every change (redline, pennzoil pure platinum, Mobil one, etc) just to ensure things stay clean.
    One option to consider(y).
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Forget it.
    Some carbon is deposited inside the engine in various places and as long as it isn't excessive, which it almost NEVER is, it is normal and won't hurt anything.
    Of course, the companies marketing "snake oil" carbon removal chemicals will try to make you think a little carbon is the END OF THE WORLD. It isn't and you don't need their products.
  7. Mendel Leisk
    42,365
    Maybe instead of removing the oil pan: just use the treatment, then do an oil change (thoroughly warmed engine, let it drain well). Drive for a few days, and do a second oil change. Examine the drained oil both times; judge from the particulate if it was warranted.
  8. qettyz
    181
    208
    Finland
    Oil pan remove was suggested because there is also steel mesh thing where oil is picked from oil pan and that can get plugged.
