carbon vapor asborber little to no difference weather in or not
Discussion in 'Gen 2 Prius Technical Discussion' started by chronon, Feb 19, 2021.
  1. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    measured about 25 g/s with and without the absorber at about 3000 rpm ..
    Without absorber :
    about 15 g/s at 2000 and about 2500 gives about 20 .. 10 happens around 11-1200 ..
    I don't route cold air in through the snorkle .. but route to pull warm air off the head area .. ambient in the 70's ... running intake air in the 90's .... hotter air is less dense and will weigh less than colder air .
    48,996
    should we remove it?
  3. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    Can you provide more details about the "carbon vapor absorber" you're talking about? Like what part it is and where it is on the car. How does it relate to the air intake snorkel?
    With the low-level detail in the post, it makes little sense to me.
  4. Mendel Leisk
    38,253
    I’m lost. Not that it takes much.
  5. dolj
    dolj Senior Member
    7,510
    3,774
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Well DUH! Atkinson cycle.
    BTW, more air in from a more open air filter = more DIRT, never a good thing.
  7. Leadfoot J. McCoalroller
    6,840
    6,484
    Pennsylvania
    2018 Prius c
    I presume you mean the charcoal filter in the engine air cleaner? The one that is there on USA models to absorb gasoline vapors from a recently shut down engine to keep them from somehow backfeeding out the air intake?
    I can't imagine it would ever make a difference for airflow- surely it's been engineered to be large enough to allow enough flow under all conditions. Heck, they're probably just using one from another car with an otto-cycle engine just to save a few pennies.
    Atkinson engines just don't care about flow.
