Cargo Capacity Calculation
Discussion in 'Gen 4 Prius Technical Discussion' started by Tideland Prius, Nov 3, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Presumably the missing Prius Gen4 Level Four/3 Eco is in the 3 big bag territory
  2. Tideland Prius
    16,668
    Probably.
    52,773
    would those be like the popcorn bag sizes at the movie theatre?
    RCO likes this.
    52,773
    you're a doctor!:cool:
    RCO and Trollbait like this.
  5. Trollbait
    12,804
    Who, CR or the EPA? I've read the standard for the EPA uses standard sized boxes like the European standards do.
    Do they state the approximate sizes for the bags?
    GM's specs for cargo space are the same for the two years. The 2015 appears to have a higher deck lid to the hatch.That may allow CR to put in the two bags and meet their criteria for this test.
    2015
    Or the guy that did the 2015 was just a better car packer;)
    RCO and wjtracy like this.
  6. bisco
    52,773
    maybe the same issue we're going through with prime.
  7. Tideland Prius
    16,668
    CR
    How Consumer Reports Tests Cars - Consumer Reports
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Finally got that PhD! Thank you!
    RCO and bisco like this.
  9. bisco
    52,773
    Professor of hybrid Drive?
    RCO likes this.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Ooooo ...I like that
    RCO likes this.
  11. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Just read all 127 pages of SAE J1100
    Cargo and luggage space are 2 very different measurements.
    Tideland not far off in his methods of measurement.
    For educational purposes see the attached images.
    Trollbait and Tideland Prius like this.
  12. Tideland Prius
    16,668
    A recent article (2014?) suggested that while manufacturers do use J1100 standards, they're not all using the latest revision method. Some are using older revision methods.
  13. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    The only thing I see is no more "open luggage area". The luggage area needs to be partitioned and hidden. So for a hatchback the area is with rear seats up and under a tonneau like cover. Still lots of room to play games with this measurement as a 1 inch change in height over 9 sqft equals 0.75 cuft. The rest are mostly Buster the Dummy related.
    RCO likes this.
  14. Trollbait
    12,804
    Thanks for the info.
    In regards to the EPA requirement, the luggage measurement is only used for cars with actual trunks. Would be great if CR, or somebody else, used this in all their reviews. Using actual luggage pieces runs into questions of whether they are empty, and if not, then how full. anybody that has actually stuffed a trunk knows that makes a difference.
    I had posted the article @Tideland Prius mentioned in at least one of these cargo space threads. The article's main focus on the difference between SUV cargo spaces, which are values not posted on Fueleconomy.gov. The J1100 required for the EPA is the one from the late '70s or early '80s. Toyota used that one for marketing materials at the time of the article. At least some of the big '3' used later revisions, which were reported to be mostly clarifications over things like the seat positions.
    Tideland Prius likes this.
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I would just like to know the actual total cargo volume, and they can let me figure out the fact that my actual luggage will have some air spaces and gaps.
    I happen to be a good gap filler.
    stephane, Tideland Prius and RCO like this.
  16. bisco
    52,773
    i would like actual dimensions. that's enough for me to take my tape measure out to the garage...
  17. Tideland Prius
    16,668
    Yes and you can watch Alex on Auto's review of the Fusion Energi. It has an 8.5 cu. ft. trunk but in his 24" luggage test, he was only able to fit one. Two wouldn't fit with the trunk lid closed.
    I have the measurements for the Gen 4 in the first post.
    RCO likes this.
  18. bisco
    52,773
    sorry, i meant prime. thanks!
  19. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    One thing I'll mention is useable cargo space, not sure if that was brought up in the thread...just skimming along. Had a Dodge Challenger before the Prius. The trunk was huge. I could hop in and close the lid, but...
    Due to the trunk being a bit on the shallow side and the rear seats not folding flat it was nearly impossible to get oversized items in the car. Not sure off hand what the cargo space actually was but the Challenger was definitely a bigger car. Now we're talking impractical vs practical but you can see that cubic feet alone doesn't reflect how much stuff you can actually stuff in the car. There no doubt in my mind I can get way more stuff in the Prius than I ever could in the Challenger, just as there is no thinking when it comes to practicality.
  20. Trollbait
    12,804
    The Challenger has an EPA trunk space of 16ft^3, which is a little more than a Camry's 15ft^3. The measurement standard for trunks actually uses a faux luggage set; one that isn't squishy as most luggage pieces. So those measurements are a conservative one of the space.
    Hatchbacks like the Prius are going to be more flexible than a sedan in stuffing things into them by their nature. The measurement standard for their cargo space relies on taking actual measurements. Since these are irregular spaces, the wiggle room in where the actual measurement is taken can lead to over or under reporting of the usable space.
    Something like what the EPA uses for trunks is used in Europe for all car types.
