Cargo Capacity Calculation
Discussion in 'Gen 4 Prius Technical Discussion' started by Tideland Prius, Nov 3, 2016.
  1. Tideland Prius
    16,680
    That's correct.
    I watched a review on the 2017 Fusion Energi and even though the trunk is rated at 8.5 cu. ft., it could only hold one 24" luggage because of its shape. Two would fit but the trunklid will not close (you'll have to bungee cord it)
  2. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    I'd like to congratulate Tideland on a great piece of work and starting this thread.
    I had to opt for the Gen4 without the spare tyre, and the risks that go with it, because of the fall in capacity from the Gen3. Without having the numbers, the usable space still definitely 'feels' smaller on this new model. If you take also consider the storage in the cabin area, it is even worse (but wasn't a deal breaker for me).
    RCO, bisco and Tideland Prius like this.
    52,849
    does the lower rear roof line drop the hatch window height?
  4. GreenJuice
    195
    127
    London, UK
    It would be better if I could confirm with figures, but yes I believe it does and also over the rear passengers heads too. You can get an impression of this when you compare the side profiles of the Gen4 vs Gen3 on pictures.
  5. Tideland Prius
    16,680
    Yes
    RCO, bisco and GreenJuice like this.
  6. bisco
    52,849
    bummer. they took our beautiful, practical prius, and sportinesses the function right out of it.:(
    RCO and Trollbait like this.
