Carista OBD-II application rocks (now Updated 4/30/2015 !)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Technigogo, Mar 8, 2014.
  1. crabbyman
    crabbyman Member
    79
    30
    Home screen [​IMG]
  2. crabbyman
    crabbyman Member
    79
    30
    First part of doors, windows, remote
  3. crabbyman
    crabbyman Member
    79
    30
    Second screen of doors, windows, remote
  4. crabbyman
    crabbyman Member
    79
    30
    Instruments, displays, dings
  5. crabbyman
    crabbyman Member
    79
    30
  6. crabbyman
    crabbyman Member
    79
    30
    Heater, A/C
  7. our1vue
    our1vue Member
    313
    58
    NY
    I'm probably the only person on the planet without a smartphone, so is there some other device this app can run on ?
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Any Android tablet with Bluetooth should also work.
  9. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Thanks for posting these, crabbyman!
    The settings available on any particular car are determined dynamically by the app based on what the car supports. There are a total of 100+ settings, but a Gen3 Prius usually supports around 30-40 of them. The next version of Carista will add about 20-30 more settings in total (not necessarily specific to the Prius). Note that even within the Gen3 Prii, there are differences in the available customizations, depending on the year, specific model, and factory-installed options.
    I have purposefully not added the seatbelt chime setting because I'm not sure yet whether there are any legal requirements about that... so I don't want to be liable or break any laws. Need to consult with a lawyer. Plus, the reminder chime seems like a good thing to have, given that seatbelts are indeed proven to be effective in cases of accidents.
    minnyprius and onlinemissy like this.
  10. crabbyman
    crabbyman Member
    79
    30
    I don't have a smart phone either..those were taken from my Nexus 7 (2012). So it doesn't even have to be an expensive tablet or setup to use it.
    Tablet - $99 (didn't buy it for this reason but the app adds to the usefulness)
    OBD II BT Dongle - $12
    Carista - $10
    GreenJuice and SAronian like this.
  11. crabbyman
    crabbyman Member
    79
    30
    For reference...I have a 2014 Prius II Base model.
    I know this a Prius board but for those who may own other cars, it only had a handful of changes for my Rav4 but it still had the one I wanted changed.
    I know the seat belt chime is a touchy subject. I would think you would get into legal ramifications as it is a safety measure. If I were you I would leave it be.
  12. StarCaller
    StarCaller Senior Member
    1,273
    723
    Cedar Crest, NM, USA
    what about adjusting the speedometer in a frame of let's say +-3mph?
    mine's slightly too fast (regarding to gps) & it would be nice to have it right on/
    Technigogo likes this.
  13. milkman44
    milkman44 Active Member
    591
    386
    Ky
    On that note, I'd like to be able to adjust the MPG readout, mine's about 2.5 MPG higher than actual .
  14. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    It's free to see what settings are available for your car in Carista. So just try it :) You only have to pay if you want to change something. That said, I don't remember seeing anything about adjusting the speedo. There might be something related to MPG in the next version, but I'm not sure yet.
    We're in the process of adding more settings. Basically, if a dealer can do it, Carista should be able to do it as well (for supported models only - we don't support the older communication protocol used by Toyotas until 2006, and for some models even later - e.g. the Gen2 Prius).
    Btw, if you guys also have other 2006+ Toyota/Lexus/Scion cars besides the Prius, it would be of huge help if you could send me a "debug report" that contains info about supported settings. To do that, open the slide-out menu from the left and tap on the "Version 2.0" label 5 times. This will open a new screen that collects info and then guides you to sending a report. Please include the exact year and model of the car. Thanks!
  15. pmike
    pmike Member
    237
    81
    Central Florida
    I downloaded it and never used it. I used the other method (free) to kill the seat belt and reverse beeping. What does it do outside the other method (free) for disabling the beeping?
  16. JGI
    JGI Member
    77
    46
    Thank you both. Looks very useful.. I'll buy it.
  17. crabbyman
    crabbyman Member
    79
    30
    See the screen caps above for everything it can change on a 2014 Two.
  18. crabbyman
    crabbyman Member
    79
    30
    The MPG thing would be a god send. That is a pet peeve of mine..I know it is just for approixmating, but if it was within 1 MPG I could live with it. Right now it is closer to 4-5 MPG off.
  19. milkman44
    591
    386
    Ky
    Will this be a simple update of the app we have or will we have to buy the new version?
  20. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    It will be a free update and if you've purchased the Pro Package, you won't have to pay anything extra.
