Carista OBD-II application rocks (now Updated 4/30/2015 !)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Technigogo, Mar 8, 2014.
  1. reaction26
    reaction26 Junior Member
    39
    DC
    Hi All,
    Any idea if there is an app or device that works for iphone and ipads?
  2. crikreef
    crikreef Junior Member
    What's new in the beta?
    SCH-I545 ?
  3. axp2948
    axp2948 Junior Member
    24
    San Francisco, CA
    I purchased the oem remote starter kit, could I use this app to enable the kit or do I still need to go stealership?
  4. famoussd
    famoussd Junior Member
    Los Angeles, California
    Can you have your phone connected to the scanner and car (streaming music and for phone calls) at the same time?
  5. CatsAreGods
    CatsAreGods Junior Member
    46
    I'm pretty sure phone calls will work, not sure of the other though.
    Nexus 4 ?
  6. onlinemissy
    onlinemissy Junior Member
    Australia
    I just had a quick look in the iTunes Store and seems there are quite a few. Please let us know how you go. I just searched OBD
  7. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    We don't have any functionality to enable the remote starter kit.
    Yes, both.
    There are no other apps (for iOS or Android) that can change Toyota settings. This is Carista's big unique feature. But there are lots of OBD diagnostic and display apps for both platforms. The ones for Android usually use Bluetooth devices (but technically can use WiFi as well), whereas the iOS ones can only use WiFi because Apple restricts standard Bluetooth communication.
    We're looking into creating an iOS version of Carista: see Carista for iOS (iPhone / iPad / iPod touch) | Carista OBD2 - Vehicle Diagnostics and Customization
    famoussd likes this.
  8. crikreef
    Repost. What's new in the beta?
    SCH-I545 ?
  9. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I'm just happy i finally got the beep to stop, I'm installing the Beta today to see whats new.
  10. Sprint76
    Sprint76 New Member
    Downloaded from the play store and connecting through OBDlink MX. Keep getting the error that my vehicle isn't supported for customization. 2010 level II. Any suggestions? Tried on 2 different phones.
    LG-VS980 ?
  11. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Some new settings are available, but not many for the Prius specifically. The connection to the vehicle is now more solid, so it's possible that you'll see new settings and/or error codes from more computers in the car.
    Thanks for testing. Please let us know if everything is working fine.
    The OBDLink devices are not supported for Toyota-specific features (like customization) because those devices comply with an older version of the ELM327 chip interface (version 1.3a). Carista requires an ELM327 version 1.4 or newer for that functionality. See Hardware | Carista OBD2 - Vehicle Diagnostics and Customization
    THAT SAID, the new beta does add some support for these older interfaces. However, it may not have access to all settings that you'd otherwise see with a v1.4 device. Feel free to try it here: Beta-Testing | Carista OBD2 - Vehicle Diagnostics and Customization
    CatsAreGods likes this.
  12. Sprint76
    Sprint76 New Member
    Thanks! The beta works great. Any chance you will be adding more features (specifically the reverse beep) that are compatible with the OBD Link or should I grab a ELM327 adapter?
    LG-VS980 ?
  13. Markee
    Markee Member
    336
    South Florida Broward County
    I'm having trouble trying to install a newly bought BAFX ELM327 adapter v1.5 on my Galaxy S3 with my Prius 2010
    I plug it in the Prius port getting a single red light staying on the adapter I turn the car on then I go into my phones Bluetooth setting and no OBDII or OBD or anything close to that showing up in there I press bluetooth detect and still not showing up
    All my other devices are showing up fine under bluetooth
    Something I'm missing ?????
  14. StarCaller
    StarCaller Senior Member
    1,282
    732
    Cedar Crest, NM, USA
  15. Markee
    Markee Member
    336
    Yeah same exact adapter
    I been trying it again and again all night with the car running with the car off tried unplugging it and plugging in again and no detect freeking sucks just not showing up
  16. Markee
    Markee Member
    336
    Got it finally
  17. StarCaller
    1,282
    732
    so what did you do to make it work?
    BION
    StarCaller
  18. Markee
    Markee Member
    336
    I have a lot of crap in my bluetooth page it wasn't showing up as OBDII or OBD in there it was showing up as what looked like a ip or mac address until i clicked on it then it changed to OBD I thought it was just something related to my pc
    Now I just need to figure out how to use the Torque app to shut down the reverse beep and seatbelt beeping
  19. StarCaller
    1,282
    732
    @ Todor: wouldn't it be possible to add a function to see the tire pressure? I was just playing around with my tis-tool & thought about this/
    would be way more convenient than checking it by hand every couple weeks....
  20. StarCaller
    1,282
    732
    to reduce it to one beep you can use the carista app (there's no way you can silence it completely), for the seat belt reminders you need either the tis-tool or you have to go to a dealer & get it done there/
