Carista OBD2 limitations and successes
Discussion in 'Prime Main Forum (2017-2022)' started by Dmitriy Sokol, Feb 1, 2017.
  1. CharlesH
    2,798
    1,166
    Roseville, CA
    I had the dealer turn it off in my 2012 PiP, and I turned it off myself on my Prime with the Carista app. What did it for me is how the backup beeping masks IMPORTANT alerts from the various proximity detectors. I know I am backing up, but if I am about to crunch into something/someone, I really want it to get my attention.
    #21 CharlesH, Jul 6, 2017
    Mark57 and dalcon95 like this.
  2. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    True. I should try that. I did it myself on my gen2 and can’t remember if it was a single beep or no beep.
    dalcon95 likes this.
  3. CharlesH
    2,798
    1,166
    Roseville, CA
    The Carista app says that it will work with other adapters, as long as they support the required OBD2 protocols and have Bluetooth (or WiFi for iOS, I think). But with the Carista adapter, you get a free month of premium functions (setting the backup beep is one of them).
    priuscatprimeguy and dalcon95 like this.
  4. CharlesH
    2,798
    1,166
    Roseville, CA
    At least on my former PiP, and on the Prime, I don't think you have the option to turn off the backup beep completely. It is either one beep or continuous beeping.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    What I actually like about the Carista app is that its functionality is limited to customizations and diagnostic fault codes and such, and cannot muck around with Engine Control Unit parameters and such. One can really mess up your car fooling around with those. For those who want to tread in those waters, there are other apps suited to that pursuit. Sort of like my philosophy as a computing professional, where I really prefer to do my day-to-day work on the computer logged in as a non-administrative user, to protect me from myself. If I have to, I can go into super cautious mode and get administrative credentials, but that is not day-to-day.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I have the BAFX adapter and Carista works fine:D
    Qmo and Prius from Dad like this.
  7. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    At least for the Carista adapter, it is really asking for trouble to leave it plugged in, since anyone within Bluetooth range can attach to it, without any authentication.
    Qmo likes this.
  9. Amy In Wyoming
    Amy In Wyoming Junior Member
    Cheyenne, WY
    I just got my Carista adapter and happily turned off the reverse beeping. I cannot seem to find the option for the proximity sensor? Anyone help me there?
  10. hill
    9,039
    can you turn off the annoying low speed noise?
  11. jungleland1972
    73
    65
    Chesapeake Beach, MD
    I just did the same (with the Carista app and a BAFX OBDII device) but didn't see anything for the proximity sensor. I was also hoping to adjust the hold time for the remote climate start (so I wouldn't have to wait for 10 seconds) but didn't see their either.
  12. Gianni I
    Gianni I Member
    72
    40
    Long Island
    Is there a setting to beep when having turn signal on and a car in the blind spot.
    So when the blind spot monitor flashes in the mirror when the blinker is activated and it senses a car have it beep. My brothers Kia does that and I think that's a great feature rather than just having the light blink.
  13. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I see Parking sensor beep volume in post #3
  14. benagi
    benagi Active Member
    525
    280
    Utah
    Is it possible to reprogram the seatbelt beeps to either be less or even turn down the volume with the Carista app?
  15. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    anyone know when there will be updates / more options to change in the app?
  16. jungleland1972
    73
    65
    I turned off the seatbelt beep with the Carista app (my wife doesn't put her SB on when driving from one store to another within the same large parking lot and it got really annoying).
    benagi likes this.
  17. geguia
    geguia Active Member
    210
    108
    los angeles
    so i cant do the same thing with a regular ODB2 scanner with buttons?
  18. Mark57
    2,945
    2,740
    OK
    You can if you know the codes to program into it to send to the vehicle. That's the rub. They are not going to tell you so you can use your Scan Gauge II instead of buying their product.
  19. geguia
    210
    108
    los angeles
    can i just borrow someone's unit?
  20. benagi
    525
    280
    Utah
    My son just bought a Zurich obd2 code reader. Anyway to find out if the Carista app will work with it?
