Carrying fuel cans in your car
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, Jun 18, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have been researching the legality of carrying a spare fuel can in my car since someone said it was illegal.
    Where I live, and probably everywhere, it is legal to carry less than 30L of gasoline in a jerry can in your car. I have been safely within regulations with 10L. At any rate, I had never run into any legal issues with carrying it in my car.
    My problem was with gasoline vapors escaping the can in warm weather. Other people have remarked about a faint odor of gasoline in my car, something to which I had become a bit "nose-blind" or accustomed to the odor and not noticing it. I tried deodorizers and heavier duty fuel cans, but the problem persisted. I believe the gasoline eventually migrates through the plastic. I have mitigated the problem somewhat by using a heavy metal can with a tight seal. I am still detecting a very faint odor of gasoline at times, but nothing like before, and certainly not a problem at all. I have placed the can in a cardboard box, also containing charcoal pads, which have reduced the odor considerably.
    52,860
    i used to get an odor just filling the lawn mower can and driving home one mile. definitely don't like that in my car.
  3. hill
    9,039
    NATO type Jerry cans are roughly 20L ( 5 US galons)
    Our recent 4000+ miles through >½ dozen states in the 5th wheel, we had about 8 gallons gas for the generator & 5 of diesel fuel for the Duramax. But it was cable locked into the bed of the truck. Better to get one of those trailer hitch cargo carriers for the back of a car then to keep it inside the passenger compartment. Especially if they're plastic jugs because the fuel fumes do eventually weep right through the walls. Actual steel Jerry cans, not so much. But those suckers cost a fortune nowadays.
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    My 10L metal fuel can was not cheap, it cost me $53, (and was from Aliexpress no less).
    It was the second one I got which leaked. I returned the first one, but I decided to repair the second one myself. I knew about a product called "fuel tank sealer" or something similar, but it was quite expensive and only available in a large container in my area. I used a mixture of acetone and Seal-All, which I spread around inside the can, and left it outside to evaporate. It seems to have worked, but perhaps I will give it a second coat some day.
  5. hill
    9,039
    Yeah I should have said European or USA made jerry cans are expensive, as the Chinese stuff are complete junk. The USA spec ones are often coated inside whereas the Chinese version will Rust. That's from personal experience.
    The above link is a comparison from the Chinese junk versus the good stuff.
    #5 hill, Jun 18, 2025
    Georgina Rudkus likes this.
  6. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    How do you get it to pour into the fuel filler?
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I just thought of it, a funnel. I like mine with a pour spout integrated.
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Mine performs well enough for "cheap Chinese junk." Not everything made in China is substandard. It's just that they sometimes have to build down to a price for their clients. Mine was a good effort at that.
  9. bisco
    52,860
    are they safe on a cargo carrier if you get rear ended?
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I like my chances with it inside the car.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I haven't had to do this in years since I went electric on all our lawn care tools but when I did I would simply place the 5 gallon fuel can inside a large lawn plastic bag after filling and cinch it up as tightly as I could.
    I can also say spilled gas inside a car will make for a very hard and long term problem it if soaks into the carpet and insulation (which is almost immediately). BTDT
    One can purchase a rotopax style exterior solution (with locks) for the Prius from Prius off-road.
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I can't see myself spilling gasoline inside my car. I deserve a little credit.
  13. hill
    9,039
    Some Jeeps carry them on the back end of their 4x4. Some similarly shaped SUVs carry them on the front. Pick your poison
  14. bisco
    52,860
    neither?:cool:
    hill, Mendel Leisk and Blackat like this.
  15. Mendel Leisk
    42,351
    To bell the cat: is the gas transportation a sporadic thing, say for lawn mowers and similar, or a steady, just-in-case thing.
  16. ETC(SS)
    7,559
  17. Mendel Leisk
    42,351
    ^ interesting link.
