cAstro my Prius c: Project thread
Discussion in 'Prius c Accessories and Modifications' started by Ryephile, Aug 12, 2012.
  1. wmo168
    wmo168 Member
    239
    49
    South Florida
    I got a Fiat 500 and the Prius C ride is much better as it sit lower to the ground and ride better in highway.
  2. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    If I may ask, what made you switch?
  3. wmo168
    wmo168 Member
    239
    49
    South Florida
    I didn't switch, that's my wife car that I bought for her a year ago, she still drive it but she wants an SUV next year so we will be trading that in next year.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    He got the Abarth version though. He said there is a night and day difference between the 500 and the Abarth. Almost as much as there was from the 500 to the C.
  5. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    The standard 500 rides like a covered wagon, and the stock Prius C rides like a cloud.
    The Abarth has totally different suspension from the 500 that's adequately sporting [for me] yet rides quite well. FWIW, the KW V3's I had on the Prius C had a similar ride comfort to the Abarth....well actually the Abarth is slightly bouncier due to its very low profile tires and much shorter wheelbase.
    mertechperformance likes this.
  6. krneidigh
    krneidigh Junior Member
    70
    17
    Pensacola
    WOW!!! Incredibly informative. Thank you. But how did you secure the amp? I'm leary about drilling into sheet metal.
  7. KYBlue
    KYBlue Active Member
    227
    112
    Ryan,
    Fyi - I did an aftermarket head unit, kept bluetooth (in fact got even more features with it) and did the AWSC-1 controls interface. There is 0 lag like old steering wheel interfaces, it's as fast as stock.
    The new unit can:
    1. I press pandora, it launches it over bluetooth on my android phone, and I can see/adjust stations, thumbs up/down etc.
    2. Notify me of incoming text (doesn't display, but indicates I got one)
    3. Though I have a C2, I can program the ASWC-1 to either long press my off hook button to enable PTT, or something else.
    4. The push to talk uses the built in google voice, so I can say "call wife at work" instead of the crazy oem commands...
  8. los panda
    los panda Member
    155
    23
    any trouble removing the passenger seat during the amp install?
    do i need to take any special precautions to account for the airbag sensor?
  9. Ryephile
    418
    151
    24
    Metro Detroit
    Nope, just make sure you have all the clips removed from the seat side flaps, and it should come out of the frame with a firm tug on each cushion bottom. As long as you keep away from the airbag sensors [i.e. don't reposition them], there won't be any trouble.
    los panda likes this.
  10. Whirldy
    Whirldy Junior Member
    89
  11. los panda
    los panda Member
    155
    23
    when you say don't reposition them, what exactly do you mean? where are they? i'm getting ready to do this next weekend.
    also, what did you use to mount the amp? i've only seen mdf and pine at the local hardware store, but i'm looking for a lighter wood or even some sort of high density foam - anything that is light and will hold screws.
  12. Ryephile
    418
    151
    24
    Metro Detroit
    I guess I could've said it easier! Just unclip the rear seat and nothing else.
    I used industrial grade 3M velcro to mount the amplifier to the floorpan of the car. It's adhesive is insane, to the point that you can bend sheetmetal trying to remove it. LOL
  13. JGriffin
    JGriffin Junior Member
    16
    Little Rock, AR
    Hey Ryephile,
    I've been reading up on your build here and have a few questions about suspension set-ups for the C. First of all, do you have any information on how the Tanabe Sustec Z40 coilovers that Garm installed on his C compared to the KW v3 coilovers you had on yours? You never mention adding a rear sway bar into the mix, which is something people on this forum seem to swear by - what is your thought on the one offered by Whiteline? Also, a few months ago you mentioned that you still had your Powergrid adjustable droplinks available for sale - do you still have them, and (more importantly for me, since I know very little about suspension) what advantage does installing them give? Thanks!
  14. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    I'll chime in a little since I am currently running Ryephile's old kw v3 suspension on my C right now. I also have the whiteline rear sway installed.
    The z40 and the v3 are both very respectable coilover systems in their own right. For a daily driver, it's really overkill but I love the adjustability, and the dampening but most importantly, the quality of the product.
    The rear sway bar by itself, makes a significant difference in the mannerisms of the car. It's much more stable from turn in to turn out.
    After adding the suspension to the rear sway bar, it completely transformed the car into a much more precise and sporty feel. No longer is the car "floaty". It very much feels connected with the road, albeit sometimes too much when the roads are rough. IE, you feel what the car feels.
    Can't comment on the powergrid drop links though. They do look beefy and certainly should offer a performance upgrade from stock.
    JGriffin likes this.
  15. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    What line level audio convertors did you use?
  16. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Hi B2Finity (pardon any repetition), could you tell me how to find the Whiteline rear sway for a C that you mentioned? I've been to their site but can't find it. They list one for a Yaris but claim it's not compatible with a C--though I gather this may not be true. And, if you have any knowledge about other rear sway offerings for the C, I'd appreciate that too. Mine is a 2012.
    Many thanks.
  17. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
  18. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
  19. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    B2FiNiTY, could you follow up on how you like the Whiteline sway bar now, regarding the links (which look like they'd allow twisting) and especially the stiffness (i.e., is it too much)? You mention that on rough roads, the car sometimes feels too connected--is that a result of the bar or something else? Thanks.
