Cat Defender Gen 3 converter shield modified for Prius v.
Discussion in 'Prius v Accessories and Modifications' started by Georgina Rudkus, Jun 28, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I recently completed an install of the Cat Defender converter shield on my 2012 Prius v.
    To clear the wider heat exchanger, I had to cut away a 4x3/4 inch strip of the shield at the rear passenger side shown in red in the photo.
    Instead of using the supplied aluminum rivets and screws, I used the rivet nut method that Miller Cat specified. I further modified Miller Cat's method and used stainless neoprene sealing washers, instead of fender washers and split lock washers with M6x1.0x16mm T27 security Torx screws.
    I filled the excess holes with epoxy glued on cut off aluminum large head rivets supplied with Cat Defender to fool would be thieves.
    I did not install the rear shield. cutout needed for Prius v.jpg cat defender packaged.JPG cat defender front plate rear passenger side mounting.JPG
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Crazy that anyone must do this...
  3. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    I was under the impression that the gen2 cats had high scrap value but the gen3s were not as attractive to thieves in the night. I know there are effective ways to discourage legitimate recyclers from buying stolen parts that have worked.
  5. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    They reduced the amount of precious metals in the Gen 4. The attached photo shows how large the Gen 4 cat is.
    The Gen 3 is a lot easier to remove than the Gen 2, but as the supply of Gen 2 diminishes, they will go after the Gen 3 cats. Removing a Gen 3 cat requires four cuts in the correct places, and the thief will be sprayed with coolant from the heat exchanger, which can be boiling hot.
    The piece with the greatest amount of precious metal is the one between the exhaust manifold and the rear oxygen sensor. They steal both on the Gen 2 and Gen 3, because they are really compact and easy to transport.
    #5 Georgina Rudkus, Jun 28, 2020
    acceleraptor likes this.
  6. Air_Boss
    4,259
    1,197
    New Yawk
    Crazy. Crack is whack.
  7. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
