Cat or bat smell...
Discussion in 'Gen 2 Prius Technical Discussion' started by Jo-Jo Joseph Mims, Oct 28, 2020.
  1. Jo-Jo Joseph Mims
    Jo-Jo Joseph Mims Junior Member
    17
    South Carolina & more
    I'll sometimes coast in neutral downhill or for an 1/8 mile to a stop sign(you know, bump up a .1mpg...). Invariably if I do this I get a smell like cat convo or battery, not sure which. Any ideas?
    I have a couple of hv modules that are just before needing changed out(my first time) and I have the b1s2 o2 code.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    How many miles on the vehicle?
    How are you reading the OBD2 codes? (device and app or make and model)
    Coasting in neutral doesn't increase MPG, you need to be in 'D'.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Don't shift to N while moving. Shift to P vs N at a standstill. I'm no Prius engine expert but if I had to guess shifting to N cuts the connection between the HV and drive motor. All of a sudden all that energy meant for the motor has been cut off and instead of destroying all the electronics in your car your battery acts like a cushion/capacitor to absorb it. Probably better check if the 12 V is still healthy. If I'm correct you're cooking it...
    moto g(7) power ?
