Cat shield anyone?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cnc97, Mar 20, 2020.
  1. Capcitymuffler
    Capcitymuffler New Member
    Sacramento
    Or everyone could save money and the extreme labor on the install and purchase the original patent pending product cat security™️ That is installed with aluminum and stainless steel hardware that are both corrosion resistant that can be installed in under 30 minutes by a professional With simple tools which doesnt require a tool you will throw across the garage while frustrated and only use once.
    Moving Right Along likes this.
  2. wasambi
    wasambi New Member
    San Jose
    Louvers all the way.. those simple cutouts aren't going to let much airflow in or out and cause way more heat to build up on the catalytic converter..
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    No thicker then that metal is, it’s not going to be enough to cause an issue.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    After a rash of converter thefts in my city, I bought the Auto Defender off eBay. I’ll get some security torx screws and use my rivet nuts that I already have on hand to install it.
    They did arrest one guy, but he obviously had help. He had been turned away from at least one recycler in the area. $12k in sales to one recycler since May. He had sawzall and stolen cats in his possession when arrested.
    Georgina Rudkus likes this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    cat defender front plate rear passenger side mounting.JPG cat defender front plate rear passenger side mounting.JPG The rivet is fake, It is cut down and epoxied in place.
  6. Priuuusss
    Priuuusss New Member
    im wondering if you can provide the sizes for both stainless steel rivets and and washers. im going to do what you recommend but want to make sure i buy the correct sizes the first time lol
    Eric.B likes this.
  7. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    1/4 inch for the front bolts. 3/16 would work for the others, but 1/4 will works better, if you need to drill holes in the car,s rails.
  8. Priuuusss
    I probably should mention that I have a 2nd gen. Does that make a difference or 1/4 still?
  9. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Yeah, all 1/4 inch rivets would be the best. They will fit the existing front hoies with no drilling.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Here's what the cat shield from Cap City Muffler looks like installed on the Gen3 ;):
    mikey_t and tonosama like this.
  11. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Here's a full cat defender shield mounted on Prius v.JPG view of the one installed on my v.
    mikey_t and Raytheeagle like this.
  12. Riparious
    Riparious Junior Member
    Got my MillerCAT guard installed last night. Painted it orange to liven it up a bit.
  13. Millard Arnold
    Millard Arnold Junior Member
    winston salem, nc
    How do I get your simple production method, other than reading your post? I have a gen 4 Prius
  14. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Can't use rivets on the Gen 4, as they do not come in sizes that large and long.
    Instead of the 12mm head M8 bolts, you can use ones from this set,
    Then, fill the security Torx heads with putty or duct seal like this;
    Gardner Bender 1 lb. Plug Duct Seal Compound-DS-110 - The Home Depot
    To get them off, the thief would have a time consuming and tedious job of digging out the sealant while under the car with a micro flat blade screwdriver. Otherwise, even the correct security bit will just spin on top of the head.
  15. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I purchased a Cap City Muffler Cat Security set for our Gen 3 consisting of the aluminum plates.
    I also have some medium gauge 1/2 inch square stainless steel screen.
    Any thoughts on cutting the stainless steel mesh to match the shapes of the plates and riveting them in-between the aluminum plates and the frame of the car to make it even more difficult to cut through the aluminum plate with a Sawzall?
    The wires should be visible through the fancy cutouts in the aluminum shields and hopefully act as a further deterrent to cut through the shield.
    #35 xliderider, Apr 28, 2021
    Raytheeagle likes this.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    That’s a thought. If the end result makes them look for another target, it’s mission accomplished.
    xliderider likes this.
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    There's been a rash of catalytic converter thefts from our parking structure at work. Two Priuses were hit within a week, along with some smash and grabs.
  18. xliderider
    8,140
    3,280
    Honolulu, HI
  19. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    I have the CUSCO strut tower brace. My dad's friend made and sold the front bar braces. I purchased and installed the strut tower brace, before he came out with the two point under brace.
    From my dad's friend's studies, he discover that both had the same effect of stiffening the strut towers. If I had known this, I would have went with the two point under brace.
    It took me five hours to install the $200+ strut tower brace. I had to disassemble the wipers and the cowl.
    My dad's friend installed his under brace in 15 minutes without even jacking up the car. He sold them for $90 delivered.
    It's live and learn from experience.
    #39 Georgina Rudkus, Apr 28, 2021
  20. xliderider
    8,140
    3,280
    Honolulu, HI
    It took me a few hours to cut the wires with a hand tool and to bend all of the sharp ends over the edges of the cat shields.
    My hands are blistered and sore, with lots of cuts, scratches, and puncture wounds from the sharp wires.
    But it looks pretty good IMO. As you can see, I decided to put the stainless steel wire on the outside surface instead of the back. 20210501_191426.jpeg 20210501_191447.jpeg 20210501_191455.jpeg
    mikey_t and Georgina Rudkus like this.
