Cat shield anyone?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cnc97, Mar 20, 2020.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The prospective thief is going to utter two words when they slide under your car and see that.
    Challenge Accepted
    Seriously though, if that doesn’t steer them away, I don’t know if anything will.
    xliderider likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    Nifty! You should have wore gloves and saved your hands. :)
    All these devices are deterants.... Short of ending their lives, if the thief wants something,
    they will do almost anything to get it.
    The harder you make it for them to get it, the more chance they have of getting caught.
    Nice job!
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    Really nice set up.
    As soon as thieves realize that Gen 3 cats have about the same amount of precious metals and the Gen 2's , and are as easy to cut out and remove with the same technique as the Gen 2's, they will go after them.
    Since there is no aftermarket C.A.R.B, replacement for Gen 3 cats, it is safe to conclude that the Gen 3 is an ultra low emission vehicle with a high precious metal content converter.
    If you had to do it again for any reason, you might purchase one of these, which is also available at air conditioning too outlets and stores like Home Depot.
    6 in. Straight Jaw Sheet Metal Seamer
    xliderider and Raytheeagle like this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Doh, yeah that metal seamer tool would have been a really good tool to use. :)
    It would have saved a lot of time and probably spared me some of my battle wounds lol.
    I didn't have any heavy leather gloves that would fit, plus they would have been hard to do the task which required a lot of manipulation of the cutting pliers and my needle nose pliers I used to bend the wires over the edges. That's where the seamer really would have helped.
    I have some epoxy putty somewhere, I just have to find it. I am going to use it to tack down the wire to the shield to further secure it to the shield, and prevent any vibration between the wire and the shield.
    Mounting the shields is probably going to have to wait until next Friday or Saturday though.
    Georgina Rudkus likes this.
  5. ASRDogman
    8,065
    4,086
    I had forgot to ask, are you going to solder the wires??? It should keep the vibration down...
  6. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Epoxy, like JB Weld is the way to go. It's hard to weld stainless steel to aluminum.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Yeah, I don't want to subject the 6061 aluminum to any heat that might affect the temper of the material. Although, I'm sure it will get plenty of heat next to the exhaust system in its lifetime.
  8. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Excellent choice.
  9. ASRDogman
    8,065
    4,086
    Soldering, not welding, is a lot lower temp, lower than the exhaust heat....
    Either way should keep it from rattling...
  10. xliderider
    8,140
    3,280
    Honolulu, HI
    The large cat shield will be a giant heat sink, conducting the heat applied away, so the only way to get solder to stick to it would be to heat it up locally to a much higher temperature than would be normally required.
  11. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Aluminum becomes soft and loses temper at around 500 degrees
    It melts at about 1100 degrees F.
  12. ASRDogman
    8,065
    4,086
    Does it not stick to stainless steel well? Both the shield and wire are stainless?
  13. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Austensic 304 stainless steel doesn't melt until 2300 degrees F.
  14. ASRDogman
    8,065
    4,086
    I don't mean melting, I meant does the solder NOT stick to the stainless steel?
    Or do you have to do it a different way?
  15. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    You can solder stainless steel to stainless steel, but not aluminum to stainless steel. His shield is made of aluminum.
    Adhesives including epoxy has been used in aircraft constructed of metal since the De Havilland Comet in the 1950's.
    It is now used universally in the automobile industry.
    Unlike rivets and screws, the stress is spread over a wide area, instead of a local point that would result in stress risers.
    #55 Georgina Rudkus, May 2, 2021
    mikey_t and ASRDogman like this.
  16. ASRDogman
    8,065
    4,086
    Makes sense, thanks!
  17. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    The current popularity of carbon fiber structural components is deceiving to the general public.
    A major component of these panels is epoxy which is a catalyst hardening thermosetting plastic.
  18. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    If I was doing it, I would cut 1/2-1 inch strips of thin aluminum flashing to go over the ends of the stainless steel wires and glue the sandwich together with epoxy, clamp it together with strips of wood until the epoxy hardens overnight. This will add additional surface area to the glued line. Gluing just the wires to the aluminum would have week stress points described by engineers as "stress risers."
    mikey_t likes this.
  19. soberups
    soberups Junior Member
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I have no issue with overheating at all. Even when driven 80+ on the highway, nothing abnormal about temps, converter or coolant.
    Raytheeagle, mikey_t and Jim Swart like this.
