Catalyst/Evaporative System/Oxygen Sensor NOT PASSED
Discussion in 'Gen 2 Prius Main Forum' started by sanlen, Jul 12, 2020.
  1. sanlen
    sanlen Junior Member
    42
    Phnom Penh
    I used the ELM 327 ODB ii to perform the Emission Tests on my 07 Prius and as result i get the information as below. However, there is no check engine light shown on the dashboard.
    1. Catalyst --> NOT PASSED
    2. Evaporative System --> NOT PASSED
    3. Oxygen Sensor --> NOT PASSED
    Can you please advise what are the problems and what is the effect on the car performance?
    52,863
    how many miles/km on her?
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    What OBD2 codes (DTCs) have you retrieved from the vehicle already? (example: P0420)
    If you're resetting the DTCs via the OBD2 scanner or the 12v battery, don't do that and expect to pass the emissions test.
    Does your vehicle have to pass an emissions test in your country?
  4. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Not sure what app does this test you did, but I suspect it's not a very good app... Most apps are customized for hybrid cars... Try Dr. Prius app instead... As for these emissions tests please give more details about what you're using?
  5. JerryScript
    JerryScript Junior Member
    43
    38
    After resetting codes or disconnecting the 12v battery, you have to drive at least 50 miles before the computer will show emissions systems as operative.
    PriusCamper likes this.
