Catalytic Converter Attempted Theft - Making Noises After Repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Friendlyx, Jan 25, 2021.
  1. Friendlyx
    Friendlyx Member
    187
    47
    Stockton, CA
    Good Morning everyone! I am once again asked about a catalytic converter on my 06. Again there was someone trying to steal it from my Prius. However, I'm guessing someone at work spooked them because they only cut one side off which was the side near the o2 sensor. They did cut the o2 sensor and that side of the catalytic converter, however they didn't actually cut the other side. We decided to take it to someone to put it back on and also replaced the o2 sensor too. However, now there is a small sound left behind that sounds like what the car sounded before i put back the catalytic converter but in a much small contained sound. Is there any reason why? We did replace the catalytic converter once and didn't have this issue. There is no check engine light, we've tried disconnecting the 12v but nothing.
    Thanks in advanced!
  2. JC91006
    16,674
    8,519
    If there is noise, it just means there is a leak somewhere. Maybe the 02 sensor is not installed correctly? If they welded the cut pipe back, maybe there's a leak where the pipes are welded. You should just have the shop that did the work, recheck it
    SFO likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Probably used pipe clamps instead of welding it and it’s leaking.
    Welding it is pretty cheap like $80.
    when my cat was replaced they used an big adapter collar where the thieves typically cut into it the muffler guy showed me and that made it twice as hard to cut it off. Twice as thick. Plummer’s pipe cutter would not work and if they used a sawzall it would take more time than stock and be ungodly loud.
    if your cat gets stolen ask the muffler guy to weld a bigger pipe over the connection it will make it more time consuming for the thieves.
    Duke the muffler guy $20 and tell him try to make that connection hard to sawzall it off weld anything you can onto that section. There going to get it if they want it but more time under there means more time to catch them.
