Catalytic converter code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bslamb, Sep 14, 2018.
  1. bslamb
    bslamb Junior Member
    So, my 2008 Prius is throwing a catalytic converter code. With most convential gas cars I know a bad cat can affect gas mileage and performance but how crucial is a good cat on a Prius? Doesn’t sputter, act funny or anything odd but curious if a bad cat in a Prius effects anything? Thanks in advance for your reply!
  2. JC91006
    16,487
    8,401
    How many miles on your car? Is your check engine light on?
    thesaint likes this.
  3. bslamb
    190k. Yes the check eng light comes on but I keep resetting it with the OBD2 scanner but just want to fix the issue now. I’m in CA read I need a CA cat. But also reading a O2 sensor may fix the issue also.
  4. JC91006
    16,487
    8,401
    If your car burns oil, then your cat would be affected.
    You might lose a few mpg but it won't affect much else. A California cat will cost you over $1500
  5. bslamb
    Burns a little oil, but not too much. Read that the oil burning does cause them to fail. Thanks for the info!
  6. JC91006
    16,487
    8,401
    You will be fine until you need to smog the car or sell it. You will need to pass smog.
    What code is the scanner picking up?
