Catalytic Converter Failing? Need Assistance with Data
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KennyP, Feb 1, 2016.
  1. KennyP
    KennyP New Member
    Virginia
    Need some of the Prius Chat experts to look over the freeze frame data to see if I’m indeed having a catalytic converter failure.
    History – After scanning the Prius Chat forum concerning battery module replacement I decided to buy an 05 Prius at an auction that had a known HV battery failure. (Special thanks to ryousideways for his very in-depth thread on battery module replacement with inputs from jdenenburg and others). I replaced three bad modules and balanced the battery as instructed and the battery is performing wonderfully. Once the car was running, I replaced the MAF sensor and one fuel injector based on codes that were generated.
    The car runs great now, but I keep getting a P0420 “Catalyst System Efficiency Below Threshold Bank 1” code that will pop up anywhere 25 to 350 miles after I reset it. I have recorded the freeze frame data in the attached file.
    I used some fuel additive in the first tank of gas to make sure any water that might be in the fuel wouldn't cause a problem (I don't know how long the car sat). I also ran some 93 octane, some non-ethanol 87 octane and then regular 87 octane (10% ethanol - hard to find non-ethanol gas around here) and recorded the freeze frame data each time the code appeared.
    I wanted to make sure the code wasn't due to another sensor before replacing the cat.
    Anything stand out in the data that would point to something else?
    Thanks for your time.
    Ken
    Dino33ca likes this.
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Could also be the O2 sensors going out.
  3. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    One sure way to check is to replace your after CAT O2 sensor and see if the activity is a lot less than the before O2 sensor is.
    If its the same it means that the CAT is not doing its job and needs to be replaced. In your situation of there were long time missfires from one cylinder the high amounts of gasoline has compromised the efficiency of the CAT. You can check on YouTube on videos where some have tried to 'scrub' the CATS and tried to clean them but your results will vary. The best repair is to get a NEW CAT and both O2 sensors.
  4. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    How many miles on her? Does she use much oil? There are cheep cats out there that will do the trick. Just do a search here on PC...
  5. KennyP
    KennyP New Member
    Virginia
    It's got 160,000 miles but doesn't seem to burn any oil. Compression checks on the cylinders were all good.
    The front Air-Fuel sensor and the after O2 sensor seem to respond very quickly like they are functioning properly base on the live data from the scan tool. I've heard that when they start to go bad, they become sluggish. However, the after O2 sensor seems to read between 0.7 -0.9 most of the time. I don't know if that's normal.
    I'll check out the YouTube videos on scrubbing the CATs to see if that will help.
    If scrubbing the CAT doesn't fix it, I'll try replacing the after O2 sensor.
    Wouldn't the P0420 code be thrown shortly after resetting it every time if the CAT was bad, rather than waiting 350 miles? I'm not sure what else the ECU looks for to generate the code besides the AF sensor and the O2 sensor.
    One other thing I've noticed in the data, sometime the barometric pressure is down to 12 psi. Is that normal?
    Thanks,
    Ken
  6. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    If those temps are correct on the cat, fore and aft, then it looks like the cat is bad, but you said you replaced a bad injector, was it stuck open or closed. If open then it may have dumped too much fuel into the system and caused a carbon blockage at the front end and causing the issue. It may just need some time to burn it off and out.
    Remove the O2S and see the condition of them, You can tell right away if they are fouled up with carbon. A torch can clean them up pretty well, in fact put a volt meter on it when you torch it to see if it will read 1 volt with a flame to it.
  7. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    I've heard when the cat goes it does so very gradually, usually owners can get close to fifty k miles before the car starts driving poorly. Depends on oil loss though. It's kind of surprising to hear of a cat going without fairly large oil loss, so maybe it is your sensors? Are you reading codes from a Toyota tech computer program? The car is running great as you say, so I don't think you should rush into buying a new cat just yet till you knock off all other possibilities....
  8. KennyP
    KennyP New Member
    Virginia
    The long term fuel trim was reading around 20 when I had the misfire so I assume it was running rich. The code reader is a Harbor Freight scan tool. A Toyota tech tool would be really nice but for my weekend garage, Harbor Freight will have to do.
    What would normal Cat temperatures be?
    I do notice that the average fuel mileage is increasing with each tank of gas. It started out at about 40 mpg. The next tank was 41, then 42, etc. It's now just over 45. I'm hoping that the Cat is fixing itself, either that or I'm getting better at driving a hybrid. I've got 3000 miles on it so far and most of my commute is around 65mph. Don't know if that's reasonable for an 05 model.
  9. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Cat temp if healthy should be pretty equal in & out.
    As far as better MPG, as you use up the gas it lightens the car ergo better gas mileage.
  10. KennyP
    KennyP New Member
    Virginia
    Ahh, if that's the case, I'll watch the temperature spread to see if it gets closer over time.
    As far as the MPG, that's average per tank. I've run about 7 tanks of fuel through the car and each one seem to be getting a little better fuel mileage.
  11. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    #11 Dion Kraft, Feb 4, 2016
  12. KennyP
    KennyP New Member
    Virginia
    Thanks. From the scanned live data, I believe that the rear O2 sensor is not varying much. It seems to go between .7 to .9 most of the time which seems inline with the above. I've got an Air-Fuel sensor up front and it seems to go from 3.2 to 3.4 most of the time. I'll have to check and see if the scanner can download data to graph. Since it doesn't have an O2 sensor up front, I don't have that data to compare.
  13. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
    #13 Dion Kraft, Feb 4, 2016
  14. KennyP
    KennyP New Member
    Virginia
    Right. The O2B1s1 is the Air-Fuel Sensor. It's readout is always around 3.3 whereas the O2 sensor is usually between 0.1 and 0.9. The scanner apparently doesn't designate the difference with the label. I'm not sure what year Toyota replaced the front O2 with the AF sensor but it's apparently on the Gen IIs.
  15. Vince9022
    Vince9022 Junior Member
    Louisiana
    I have an 05 Prius as well, same P420 code. I have 200,000 miles. I cleared code and after a few miles come right back. Tried seafoam, Lucas, Cataclean, and same results. I finally decided to just change the Cat cause I was tired seeing the Check Engine Light. I found an aftermarket one on eBay for $193 brand new direct fit (Magnaflow Brand) *Not for use in California*. Took it to a local muffler shop and guy put it on for $30 bucks. On the ride home the Check Engine Light cut off. Hope this info helps anyone with Cat problems.
  16. JC91006
    16,936
    8,647
    That catalytic converter from Magnaflow is actually about $100 on Amazon
  17. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    $193 vs $100 part, ouch. Maybe OP will start price shopping w/ Amazon and others big stores.
