Catalytic converter gutting?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sharnold, Sep 20, 2019.
  1. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    Has anyone seen or heard of this mod on a Prius? Will it show Dtc because of back pressure reduction from the 02 sensor?
    #1 Sharnold, Sep 20, 2019
    52,880
    is there a link? i have ad blocker
    Sharnold likes this.
  3. Sharnold
    409
    126
    Alabama
    I corrected my post it was supposed to say mod* not model sorry
  4. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
  5. Sharnold
    409
    126
    Alabama
    Ok let's try this again........ Has anyone ever heard of someone modifying/gutting the catalytic converter on a Prius? Would the modification cause there to be a loss of backflow/back pressure causing the oxygen sensors to read wrong and a DTC code to be present in anyway?
  6. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    They may have done it. However, please don't. By gutting a catalytic converter, a person doing this both breaks the law and causes very real harm to other people. There is a reason this is against the law.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    back pressure isn't what will set the CEL, its the incorrect voltage signal from the O2 sensors. I don't think there would be any advantage to gutting the cat; it worked with old carbureted engines, but the real choke point on a prius is gonna be the tiny exhaust pipe behind the cat. instead of ruining your cat, look into a custom exhaust system after the cat. whether there is any possibility of getting a bit more power is a whole other can of worms...
  8. Sharnold
    409
    126
    Alabama
    Back pressure/airflow will set the DTC if you gut the cat because the exhaust is moving faster than 02 sensor can keep up with giving false readings..... I would never do this to somebody else's car this was a hypothetical question one of my friends asked about
  9. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Don't gut your Prius cats! It won't work and they are valuable in scrap. If they have failed, replace them with high quality aftermarket cats, and sell me your oem units. You can contact me here or on my cell 6312915509
