Catalytic Converter Install
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Oldmanriver, May 11, 2021.
  1. Oldmanriver
    Oldmanriver Junior Member
    28
    Pittsburgh, PA
    Hello what are my options as far as Cat replacement. I have a project Gen3 with a bad cat and looking into my options for a replacement and what has been done to address the coolant lines. All of my searches produce results regarding Cat theft deterrents. Thanks in advance!
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,166
    2,210
    Taylors, SC
    You need to purchase a new converter like this one.
    Catalytic Converter For 2010 2011 2012 2013 2014 2015 Toyota Prius 1.8L EPA | eBay
    Carefully cut off the old cat before the pre-heater without cutting the coolant lines.
    Position and tack weld the new cat to the pre-heater.
    Clamp off the coolant lines before the pre-heater, remove the clamps and take down the cat with the pre-heater and resonator attached.
    Fully weld the connection between the converter and the pre-heater.
    Reinstall the entire unit, top off the coolant, and you're done.
    #2 Georgina Rudkus, May 11, 2021
  3. Mendel Leisk
    38,709
    Not sure I understand the sequence as described above; the old cat comes off BEFORE the new one is tack welded, no?
  4. Georgina Rudkus
    3,166
    2,210
    Taylors, SC
    Unfortunately, I do not want to elaborate, because this is the very technique used to cleanly and easily steal a Gen 3 cat.
  5. ETC(SS)
    6,553
    University of YouTube.
    School of Automotive Technology.
    Your instructor will be "Four Fingers Frank" who is on a work-release program from the Department Of Corrections.....
    douglasjre and Mendel Leisk like this.
  6. Georgina Rudkus
    3,166
    2,210
    Taylors, SC
    Four Fingers? If he is missing his pinkie, he must be a member of the Yakuza.
  7. ETC(SS)
    6,553
    Sawzall accident......
    Grit likes this.
  8. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    priuscamper would beg to differ.
  9. Mendel Leisk
    38,709
    Most folks only have four fingers per hand. Just sayin...
  10. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :ROFLMAO:
  11. Mendel Leisk
    38,709
