Catalytic converter protection: Auto Defender vs. Cat Shield?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NewHybridOwner, May 17, 2020.
  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Can you install Auto Defender or Cat Shield if you have Cusco brace?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
  3. diggie
    diggie Junior Member
    What still hasn't been addressed, and what I would really like to hear from Millercat, is IF there were to be corrosion on the aluminum model, would it be the shield that would be sacrificial, i.e. would the shield be corroded before the frame.
    I think this is true but presumably they've actually done the research.
  4. enpleinclaire
    enpleinclaire New Member
    LA
    2021 Prius
    can you tell me which shop did it for $40?? that’s a great deal. i’m actually looking to get a cage installed and hoping their prices are also affordable for that.
  5. Kaiso
    Kaiso New Member
    Los Angeles
    2017 Prius v wagon
    Does the shield come with instructions? Will the 2017 Prius V version require drilling? Has anyone put together clear DIY instructions with required tools, etc? Videos?
    Edit: Just saw the video on the MillerCat site.
    #105 Kaiso, Mar 18, 2021
  6. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    Not sure of this video has been posted. But here's a 3rd gen Prius cat being stolen. Gen 3 is harder to do because the 2 front bolts are hard to reach and requires 4 cuts, including the coolant lines. I believe this is in UK where the driver sits on the right. Notice only 2 tools were used, the last one being a reciprocating saw.
  7. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    So, the guy just watched them do it? Someone was holding the camera...
    Police say a man trying to steal a catalytic converter was crushed to death when the car fell on top of him - TheBlaze
  8. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    ASRDogman likes this.
  9. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    It looks like somebody holding their phone over a CCTV monitor and recording it.
  10. ASRDogman
    7,591
    3,916
    mmm You many be correct. I watched it again, and paid more attentiona and noticed
    the date/time code at the top left...
  11. Blue Prius2015
    Blue Prius2015 Junior Member
    Got it on. The stainless steel Miller cat shield. Did it myself. Drove front tires up ramps, put in jack stands, then jacked up each side at rear and left jacks in place and then added more jack stands. Rear wheel chocks, spare concrete block in place, wood pieces here and there. All that because I then slid under on my back with enough room for the 11" rivet nut tool and just enough for my drill with the 27/64 bit in it. Rubber mat and cardboard over firmly frozen stone driveway.
    An easy task to do but old bones took their time. Several hours later, holes enlarged in front, holes drilled in rear, all of the threaded rivets set in place. Corrosion resistant spray applied to steel brushed framework. Miller sent adhesive backed foam strips for the front edge and had thick metal washer spacers for the rear bolts. Took this Gen 3 Prius for a drive and only a few times, accelerating, going around a curve and uphill did we hear a bit of a whine. Possibly the vent fins over the cat converter, but not enough to warrant revisiting the car's bottom.
    Will probably sleep a bit firmer at night now. Added the two Cat stickers to the car to steer the wrong people toward some higher pursuit.
  12. Blue Prius2015
    25/64 is correct bit dia. Not 27/64.
    11" rivet nut tool works great for a gorilla. Had to use 2 hands on one arm, placing the other tool arm against my shoulder. Several squeezes were needed.
  13. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    3/8 inch will work as the expanding end will fill the gap.
  14. Miller CAT
    Miller CAT Junior Member
    25
    49
    San Jose, CA
    Looks like they were checking for a shield
  15. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    Wonder if the UK Gen 3 Prius has all of the coolant that will leak out when the preheater lines are cut?
    icyrius, RichardY and Merkey like this.
  16. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    On second thought, these thieves have got to be real professionals.
    They knew exactly where to cut to avoid the coolant preheater lines, unlike the crude amateurs who did the attempt in the Muffler Tech video.
    To avoid informing would be thieves, I will not post any diagram showing how easy it is to steal a Gen 3 cat.
  17. priusjersea09
    priusjersea09 New Member
    Jersey city
    Do you have any suggestions for the stainless steel (millercat) version of the shield? Especially since its much harder to bend
  18. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    I have the Auto Defender aluminum shield on mine. I used M6-1.0X30mm bolts on mine. On the two center front bolts, and all five rear bolts, I placed a round, chrome 1/2” diameter x 3/8” tall spacer between the plate and the underbody of the car. No resonance, and no issue with the plate rattling against the exhaust pipe. And the chrome spacer is going to be at least as hard to cut as the plate is.
    #118 cnc97, Apr 13, 2021
  19. Georgina Rudkus
    3,465
    2,429
    Taylors, SC
    Sheet stainless steel will bend just like aluminum.
  20. fuzzy1
    10,452
    What else could a Brit do about it? It isn't like their police care about this simple property crime. Or that their citizens have any rights or tools useful for attempting to accost or detain the thieves.
    Filming the heist is about their only legal response.
