catalytic converter replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dilaman99, Jan 13, 2020.
  1. dilaman99
    dilaman99 New Member
    Georgia
    Dealer is increasing quote on catalytic converter replacement. They say that the cooling part of the hybrid battery is in that area and they need to drain it to replace the catalytic converter so they tacked an additional $300.00 to quote. Sounds very fishy to me. Why would they put the cooling system next to something hot?
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    oil filter is kinda close to the right front wheel; ask them if they have to drain the oil before they can change tires.... /
    the catalytic converter has a connection to the radiator fluid, but this connection cab be blocked off before replacing the catalytic converter, so there is NO need to drain the cooling system /
    SFO, Rebound, m.wynn and 1 other person like this.
  3. Mendel Leisk
    38,718
    They're maybe slavishly following the Repair Manual instruction, and it would be the engine coolant I think:
    But it seems odd, that they wouldn't just clamp off coolant lines. Or pull them off and quickly push on a stopper, which is easier on the hose, and more effective I think.
    Full Repair Manual excerpt attached:
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    StarCaller likes this.
  5. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    $300 to drain an refill a radiator? That’s a big-time ripoff. All you need to do is remove the plastic pan beneath the engine, open a stop cock, then close it and add coolant.
    SFO likes this.
  6. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Though one could argue otherwise, the HV battery and the catalytic converter aren't exactly near one another.
    It does sound like a 'stealership' move, the only "cooling part of the hybrid battery" is forced AIR, which isn't exactly drainable.
    They must've meant "vacuum", like to vacuum the cash from your pockets :cautious:
    Could be that the service advisor (ahem, extortionist) was mistaken when describing the job requirements.
  7. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    As Mendel Leisk posted, the engine coolant runs to the catalytic converter for faster engine warm-up to improve fuel efficiency. To replace the catalytic converter, the engine coolant either has to be drained and refilled, or the two hoses that run to the catalytic converter have to be stopped while the converter is changed. Radiator drain/refill is typically half what they quoted you, however.
