Catalytic converter replacemet
Discussion in 'Generation 1 Prius Discussion' started by beth524, Jul 24, 2012.
  1. beth524
    beth524 Junior Member
    66
    Ithaca, NY
    2001 Prius
    Hi all,
    After hearing some loud noise coming from my exhaust system, it was determined that there is a hole (from rust) in part of the cat. assembly. Three shops each quoted me around $1500 replacement, as there are no aftermarket products for this unit. I have NOT gotten any error codes, the only problem is the noise. What to do? The car is 10 years old with 86000 miles. I have beeen reading about some of you getting just the one piece and having it welded on, but I do not believe any of the shops here will do that, and indicated that it would be a very temporary fix. Thanks for any guidance.
  2. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    It is probably against federal law to modify the cat (even welding on to it).. So good luck finding someone to do that. You would need a picture of where/ how bad the hole is to get any useful advice.
    I have trouble believing they can do it for even $1500 as Toyota is charging almost $1200 for the part. This cat has a HCAC valve on the front of it that all comes as one piece.
    You may be able to get some high temp epoxy putty to plug the hole, but it depends on how bad the rust is and where it is located.
  3. bobofky
    bobofky Member
    107
    There are after-market catalytic converters if you are not in California. I have had them replaced in two 2001 Priuses for less than $200 each. Search the internet and you will find them.
  4. Gen1guy
    Gen1guy New Member
    47
    2002 Prius
    As above search for OBD II compliant cat replacement or better yet a carb certified unit will get you through much the same for significantly less
    Have fun !
    Eric
  5. usnavystgc
    3,159
    990
    Tucson, AZ
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    The chance of any epoxy fixing this is probably nill. A hole indicates bad rust.
  7. ChapmanF
    17,343
    Doesn't that leave, like, $300 for installation? I can't imagine it's a six-hour job....
    -Chap
  8. David Johnson
    David Johnson Junior Member
    33
    Chicago, Illinois
    2002 Prius
    I
    I think i am experiencing a similar problem with my Prius. When I am driving over 30 MPH I can hear a loud humming sound and i thought it was my muffler. I took it to two muffler shops and they both said the muffler is fine. One guy said he believes it is the catalytic converter which I doubted until now. :( he said it would cost around $550 to replace it. But I thought the noise was coming from more towards the rear. Once I am doing around 60 - 70 mph I nearly need earplugs. My sister says it almost sounds like driving a car in low gear but when I take my foot off the gas the car coasts just fine (unlike a car would that is stuck in 2nd gear at 70 mph).
    i don't have $550. I can probably come up with $50. So what do I do? How can I be sure if it is the converter before moving ahead with the expense?
  9. bwilson4web
    16,012
    Does the hum stay or go away if you reach say 40-50 mph and shift into "N"?
  10. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    It stays around the same decibel, but isn't as loud outside of the vehicle (I drove with the door open and my head dragging on the ground).
  11. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    If you are in California you're screwed, you have to use the OEM cat. Everywhere else you have options.
    Since the OP is not in California, go to "mom and pop" muffler shop and have them weld in an aftermarket cat.
    There is even a clamp on direct fit unit (eastern 40544), but the clamp can often leak so best to have the shop weld it on. Muffler shops do this sort of thing all day.
    yotatoter and bwilson4web like this.
  12. bwilson4web
    16,012
    Good thing they are not near Nevada or Idaho where they'd probably do the welding for free. <GRINS>
  13. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    well I am going to take it to the dealership to have them inspect it for $65 to tell me what is wrong with the car. To have to pay a dealership to diagnose a problem is ridiculous
  14. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Drive to Nevada and get the work done. Spend a day and night at one if the hotels.
  15. David Johnson
    33
    Chicago, Illinois
    2002 Prius
    I
    Turns out that the loud noise I was hearing was from the bearings in the driver's side rear wheel. Toyota said the hub and bearings come as one piece for my car so that cost me around $330.00. It is running quiet now. The noise had gotten unbearable.
    yotatoter, bwilson4web and JMD like this.
  16. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Can we get an update please. Did the check engine light stay off? For how long?
  17. Oc.dreamer
    Oc.dreamer Junior Member
    32
    2002 Prius
    I
    Hi can u please post pictures of the hole? My prius is making the same super loud noise.
  18. Oc.dreamer
    32
    2002 Prius
    I
    330 for the part? Or does that include install?
