Catalytic Converter shield advice needed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by icyrius, Feb 23, 2022.
  1. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Hello,
    My son received advice to install a catalytic converter shield from his college advisor who had hers stolen from her Prius last month. I found one on Ebay for less than $50, except I would have to install it myself.
    Can this be installed even if you do not own a car lift? I only have a couple of HarborFreight ramps that are high enough for me to get under the front of the car.
    Thanks for your help.
  2. PriusII&C
    PriusII&C Active Member
    432
    146
    San Jose, California
    Not sure how high your ramps are, just make sure you have enough room under the car for the riveter and the drill you use. I did it myself using 2 small jack stands and a 10" riveter.
    icyrius likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    You can on ramps, but it's a little tight. You will need to make a clearance cut for the cat on a Prius v. The photo shows the cut needed. cutout of cat defender plate needed for Prius v.JPG cutaway of plate for Prius v.JPG
    #3 Georgina Rudkus, Feb 23, 2022
    Robert Holt and icyrius like this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    I installed the cat shield myself using jackstands at 4-corners, but I would not like to do it again. There was very little clearance to get under the car for the install, and I'm not a big guy.
    It will be very tight work if you only use ramps in the front.
    Unless you have a right angle drill, you might not have enough room to fit your drill + drill bit under the car to mount the rear shield, if only the front is lifted.
    FYI, use some oil (motor oil is fine if you don't have cutting oil) on the drill bit when you drill into the rails for the back fasteners. It will keep the drill bit from overheating due to friction, and help the bit bite into the steel, making the drilling go much faster.
    #4 xliderider, Feb 23, 2022
    icyrius likes this.
  5. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    Thanks for all of your advice!
  6. Scarface2005
    Scarface2005 Member
    93
    47
    San Bernardino Mountains
    I installed mine with a harbor freight 1 ton jack and two small harbor freight jack stands. I did not use the rivets. I used bolts from the local hardware store with grip tight nuts, the ones that can’t be hand threaded on or off.
    That way I can remove it if I ever need to. Theoretically so could a thief, but it would take him 30 minutes under the non jacked up car to remove all of the nuts.
  7. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Did you have to drill holes in the frame?
