Catalytic converter shield
Discussion in 'Gen 3 Prius Main Forum' started by PA Prius, Apr 11, 2022.
  1. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Two questions related to cat shields—
    1) The local dealer quoted me $160 for parts plus $280 for labor to install a cat shield on my 2012. Has anyone compared these supplied by Toyota with the $60. kits available via eBay? Has anyone had a bad experience (stolen cat) after having installed either of these?
    2) Some shops are offering to install an off market cat in exchange for the original and paying out $xxx. for the exchange. I know these off market brands are not acceptable in CA. I am not in CA. Do these off market cats allow the car to pollute more than with the original? Is there any reason not to go off market?
  2. JC91006
    16,925
    8,637
    "install aftermarket in exchange for original". Have you checked the prices? $100 for an aftermarket, $1600 for an original
    Aftermarket ones will last a very short time compared to an original one.
    Keep the original one and buy an aftermarket.....that's usually the route to take
  3. PA Prius
    762
    251
    SE Pennsylvania
    What would be the purpose of keeping the original?
  4. JC91006
    16,925
    8,637
    Sell it in CA (or to a recycler) for $1000 or when your aftermarket one fails, you have something to fall back on
  5. PA Prius
    762
    251
    SE Pennsylvania
    I can see selling it. Keeping it to re-install after a theft didn't make much sense to me.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  7. PriusCamper
    PriusCamper Senior Member
    13,348
    5,396
    Pacific Northwest, USA
    This is where DIY pays off... You can replace your cat with this one for $129 that comes with 5 year warranty: Catalytic Converter For 2004 2005 2006 2007 2008 2009 Toyota Prius 1.5L EPA OBD2 | eBay
    and this cat shield is only $58: Cat Shield For 2010-2015 Prius Catalytic Converter Protection Security Shield | eBay
    It takes an hour or two pull out your existing cat, replace it and put the cat shield on. And your original cat can be sold to a precious metal scrapper or auctioned online for anywhere between $800-$1600 depending on who you work with.
  8. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    Pity that post is in a gen3 1.8 forum
  9. PA Prius
    762
    251
    SE Pennsylvania
    I appreciate the comments and would still welcome responses to my original questions—
    1) Any thefts from Toyota's or "eBay" cat shields?
    2) Do the cheap after market cats pollute more than the original? (my assumption is there is a reason Toyota used such a cat in the Prius)
  10. JC91006
    16,925
    8,637
    1. yes
    2. yes
  11. PA Prius
    762
    251
    SE Pennsylvania
    Thanks. I will refrain from asking for footnotes.
