Catalytic converter stolen, any decent aftermarket options?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by leftovercrack, Jan 28, 2023.
  1. Ozzbo
    Ozzbo New Member
    29
    Austin
    Do you think I can drive 20 miles without the catalytic converter to the shop for repair? Or would it be better to deliver Prius on a tow truck?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    Yes, noisy, but you can drive it to the shop, unless you have a Gen 3 or 4 with a cut in the coolant circuit to the exhaust preheater.
  3. Priipriii
    Priipriii Member
    230
    66
    You can, itll sound loud. Also make sure to keep the windows open or have the AC NOT recirculate air back inside. If you feel sleepy, open the windows. The carbon monoxcide will enter inside from under the cabin since its not going all the way back.
  4. Ozzbo
    Ozzbo New Member
    29
    Austin
    Thanks. I will. Also I have noticed that the coolant level for the inverter is low, and the engine coolant tank looks empty. I'm going to refill both
  5. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Your profile shows a Gen 2 2008 Prius. That has no exhaust reheater . If the coolant is low, there could be other damage. Check for leaks an repair them.
  6. Priipriii
    Priipriii Member
    230
    66
    Make sure they didnt cut any coolant lines, thats the only thing i could think of why it might be low
    20 miles is pretty far drive to go without coolant as far as overheating is concerned
  7. Ozzbo
    Ozzbo New Member
    29
    Austin
    Ok. The cat has been replaced along with the oxygen sensor. Now I have a check engine light. Any idea how to fix it? Thanks
  8. Priipriii
    Priipriii Member
    230
    66
    Computer probably needs a reset so disconnect battery and reconnect. Engine light should go away
    That or white cable in the fuse box might work too
  9. Ozzbo
    Ozzbo New Member
    29
    Austin
    The Check engine light has disappeared after doing:
    - added cataclean
    - reconnect the battery
    Thanks everyone!
  10. Ozzbo
    Ozzbo New Member
    29
    Austin
    Unfortunately, the Check engine light is back
  11. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
  12. Priipriii
    Priipriii Member
    230
    66
    Id recommend taking the o2 sensor off and spraying some paint thinner inside. I did it by pouring it into the fuel tank and it got rid of the code, but it also destroyed my headgasket. It could also potentially destroy the rubber o rings in the fuel line. If i had to do it again, id just do it directly into the cat from the sensor which is pretty easy to get to
  13. Ozzbo
    Ozzbo New Member
    29
    Austin
    Update on my situation. The O2 sensor has been replaced by the OEM one from Denso. My bad. I should not go cheap at first place. Now no 0420 check engine light. Hopefully, it's fixed.
    Paladain55 likes this.
  14. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    When in doubt always go Denso. Or Aisin. Good thing to learn working on Toyotas and wanting to save time on doing it right the first time.
