Catalytic converter theft design by Toyota?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Feb 3, 2022.
  1. BiomedO1
    BiomedO1 Senior Member
    3,046
    1,621
    SacTown, Ca
    Yes, covered under comprehensive after your deductible - but it's the down time and inconvenience of it all. You probably shouldn't park it at the airport long term parking, or other such venues.
  2. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    I've seen videos where these cat thieves pull up right next to your car in a shopping mall and can have the cat out in less than a minute.
    Your comprehensive insurance should cover it, but the Prius will be undriveable for an extended period until everything is replaced.
    Stainless steel Miller Cat plate cost me about $190 (bought it on a 5% discount they offered over a holiday weekend.
    Installation was about $170 at a certified Miller Cat installer.
    Peace of mind.. priceless.
    ccna101, prius16 and pghyndman like this.
  3. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    My 20 PP will be sitting out in the street since it is where my kid dorm.
    Any report of this Stainless steel plate will send them packing?
    TIA,
  4. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    The plate and prominent decals mentioning it is installed will hopefully be sufficient disincentive to make would be thieves move on to an easier target. After all, these dirt bags want to avoid work (hassles) and move along as stealthily as possible.
    Conversely, you might install this:
  5. BiomedO1
    3,046
    1,621
    SacTown, Ca
    IMHO, any CAT shield will do in combination with a motion alarm - should be enough of a deterrent, to encourage a CAT thief move-on.
    The car must be jacked-up to get to the CAT. The removal of a CAT shield will simply slow-down a thief; but with flashing lights and alarm blaring - thieves usually don't want to stick around, since the car is drawing attention.
    ccna101 likes this.
  6. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I totally forgot ...so the factory alarm: will it detect all the locomotion? I will try it out.
  7. BiomedO1
    3,046
    1,621
    SacTown, Ca
    Factory alarm only detects door openings. A motion/glass breakage sensor is an add-on - well worth it IMHO.
    If your not sure the add-on is installed; lock the car and wait 3 minutes - then grab a fender and rock the car. No alarm - no add-on.
  8. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I been review a few thing: it is seem that the PP are not in the picture (for now) but I will add a SS catshield as a protection.
    For those who are also in the market: there are few motion sensor detector out there that hit the spot: and I am enjoy to see those crook just run like hell and leave their tool behind :)
    EV-
