Catalytic Converter Thief Stole Heat Exchanger Too
Discussion in 'Gen 3 Prius Technical Discussion' started by ap47, Aug 2, 2021.
  1. ap47
    ap47 New Member
    2010 Prius. The thieves stole the whole upper exhaust system, from the exhaust manifold joint on past the the heat exchanger. Catalytic converters and heat exchanger are gone. Coolant lines are cut.
    I don’t need a CARB-compliant fix, and I see several aftermarket catalytic-converter-only options available. But none of these have the heat exchanger/coolant line connections!
    Can’t post a link, but for example,
    “MagnaFlow® - OEM Grade Direct Fit Catalytic Converter”
    or
    “Walker® - Ultra™ Direct Fit Round Body Catalytic Converter and Pipe Assembly”
    How can I even use one of these without the coolant line connections?
    What’s more, I can’t even seem to find anywhere which sells the heat exchanger part at all.
    I am aware of this thread, but I am hoping for more explanation than is there. Catalytic converter coolant question. Would joining cut ends of coolant lines with hose work? | PriusChat
    What do people do here?
  2. tony_2018
    tony_2018 Member
    204
    61
    toyota?
    ASRDogman and Mendel Leisk like this.
  3. ChapmanF
    15,456
    I don't see why just connecting the gozinta to the gozouta would not work. You'd only be giving up the faster-warmup advantage from the heat exchanger.
    Possibly that would lead to a trouble code about the heat exchanger (B1503 from the combination meter), but I don't think that's likely. (I think the code gets set when the temperature reading coming back from the EHRS is wildly unreasonable, but if just joined with a hose, it's going to closely match the temperature circulating in the engine.)
  4. Mendel Leisk
    38,649
    Now I'm getting interested in that shield...
  5. ap47
    ap47 New Member
    @ChapmanF Thank you for your intuition about the code possibilities!
    Is it possible to buy an aftermarket heat exchanger part and get it welded in?
    Toyota only sells the heat exchanger as a part of the catalytic converter and exhaust pipe system.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,153
    2,204
    Taylors, SC
    No. Only Toyota sells the heat exchanger.
    #6 Georgina Rudkus, Aug 6, 2021
  7. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    o_O
    ap47 likes this.
  8. Georgina Rudkus
    3,153
    2,204
    Taylors, SC
    It's the hassle and co-lateral damage from the idiot thief who does not know how to do a "clean" removal that led me to install the shield.
    ap47 likes this.
